What is the proof for Gauss's law? Can you give me some explanation and details with the proof?
Gauss's law is the electrostatic equivalent of the divergence theorem. Charges are sources and sinks for electrostatic fields, so they are represented by the divergence of the field: $\nabla \cdot E = \frac{\rho}{\epsilon_0}$, where $\rho$ is charge density (this is the differential form of Gauss's law). You can derive this from Coulomb's law. For a charge density $\rho(\vec{r}')$,
$$E(\vec r) = \frac{1}{4\pi\epsilon_0} \int_\mathbb{R} \frac{\rho(\vec r') \widehat{(\vec r - \vec r')}}{\left|\vec r - \vec r'\right|^2}dV = \frac{1}{4\pi\epsilon_0} \int_\mathbb{R} \frac{\rho(\vec r') (\vec r - \vec r')}{\left|\vec r - \vec r'\right|^3}dV.$$
(This converges to $E=\frac{q}{4\pi\epsilon_0 r^2}\hat r$ for a point charge.) Taking the divergence of this,
$$\nabla \cdot E = \frac{4\pi}{4\pi \epsilon_0}\int_\mathbb{R}\rho(\vec r')\delta(\vec r - \vec r')dV = \frac{\rho(\vec r')}{\epsilon_0}.$$
Then to arrive at the integral form presented in most introductory EM textbooks, the divergence theorem gives:
$$\int_{\mathcal{V}} \left(\nabla \cdot \vec F \right) dV = \oint_{\partial\mathcal{V}} \vec F\cdot \vec{dS},$$
so in the case of electrostatics $\int_\mathcal{V} \rho(\vec r)$ is simply all of the charge enclosed in $\mathcal{V}$ so,
$$\int_{\mathcal{V}} \left(\nabla \cdot \vec E \right) dV = \int_{\mathcal{V}} \frac{\rho(\vec r)}{\epsilon_0} dV = \frac{Q_{\text{enclosed}}}{\epsilon_0} = \oint_{\partial\mathcal{V}} \vec E\cdot \vec{dA}.$$
