In galilean relativity $$p=mv$$ and $$KE=\frac{1}{2}mv^2$$
If I understand it in special relativity the equation for momentum is $$p=\frac{mv}{\sqrt{1-\frac{v^2}{c^2}}}$$ In galilean relativity there is the equation $$\frac{p}{m}=v$$ while in special relativity the equation is $$\frac{p}{m}=\frac{v}{\sqrt{1-\frac{v^2}{c^2}}}$$ In galilean relativity $$KE=\frac{1}{2}m\frac{{p}^2}{{m}^2}$$ and if this equation holds in special relativity it produces the equation $$KE=\frac{1}{2}m\frac{v^2}{1-\frac{v^2}{c^2}}$$ Is this a correct way to express kinetic energy in special relativity?
It is useful to understand how the expression for kinetic energy is arrived at in non relativistic mechanics and apply that for the relativistic case. Let's say we have a body at stand still and apply a force $F = \frac{d(mv)}{dt}$ to get it moving. The energy gained by the body is then
$ E_k = \int_0^t Fdx = \int_0^t \frac{d(mv)}{dt} dx = \int_0^tmv dv = \frac{1}{2} m v^2 $
Doing the same in relativistic mechanics you need to take into account the body gets heavier (or more "inertial") by a factor $\gamma = (1-\frac{v^2}{c^2})^{-1/2}$ with $m$ now its rest mass and the integral works out differently. Calculating the work done we will find:
$ E_k = \int_0^t Fdx =\int_0^t \frac{d(\gamma mv)}{dt} dx = \int_0^tv d(m\gamma v) $
This integral is slightly more involved but will result in $E_k = (\gamma -1 ) mc^2$. Physically a lot more work has to be done to accelerate the body as it gets heavier.
Note that in the classical case you can write $E_k = \int_0^t \frac{p}{m} dp = \frac{p^2}{2m}$ but not anymore in relativistic mechanics as you can see from the integral expression in the above which becomes
$\int_0^tv d(m\gamma v) = \int_0^t\frac{p}{\gamma m} dp$.
So your expression for $E_k$ in terms of momentum is incorrect.
Jan Bos
  • 851
Kinetic energy in Special Relativity is $KE=(\gamma -1)mc^2$, where $\gamma $ is the Lorentz factor. This is derived from the relativistic equation for total energy, $E^2 = (pc)^2 + ((mc)^2)^2$; the negative term removes the rest energy from the total energy.
The Galilean kinetic energy is the limit of this expression for small velocities.
Peter Diehr
  • 7,367
The equation for KE does NOT come from integrating force through some distance/time/velocity. You don't even need calculus. Of course that does give you the correct equation, it's more just a fun quick way to get the equation.
It's all from the true energy-mass equivalence. This works regardless of the speed you have. The approximation of it, is the standard KE used for non-relativistic stuff (as expected, since newtonian mechanics is an approximation)
Namely,
$E^{2} = (mc^{2})^{2} + (pc)^{2}$
That is the energy-mass equivalence, notice that if momentum is zero, you get the famous $E=mc^2$ (rest energy)
Then to get KE, you just need to subtract resting energy.
So,
$KE = \sqrt{(mc^{2})^{2} + (pc)^{2}} - mc^2 = mc^2(\sqrt{1+(\frac{p}{mc})^2}-1)$
Like that. If you taylor expand that square root to approximate it, you get $KE=\frac{1}{2}mv^2$. And if you sub in $p=\gamma mv$ for speeds close to c, you'll get $KE=(\gamma -1)mc^2$ after some simplification.
