In a more general context than Weyl semimetals, in any theoretical condensed matter model we are always only interested in low-energy excitations. Thus assume you have an electron of momentum $\vec{k}$ that lies just above the Fermi surface. Most condensed matter models can be accurately described in the framework of Landau's Fermi-liquid theory at low energy, meaning that the electrons behave in very good approximation as free particles with interaction-renormalized parameters. Thus the dispersion relation of your electron is just
$\epsilon(\vec{k}) = \frac{k^2}{2 m^*}$,
where $m^*$ is the effective mass of the electron. We can decompose $\vec{k}$ in two colinear vectors $\vec{k} = \vec{k_F} + \delta \vec{k}$, where $\vec{k_F}$ lies on the Fermi surface and $\delta \vec{k}$ is small with respect to $k_F$. The dispersion relation then reads
$\epsilon(\vec{k}) = \frac{(\vec{k_F} + \delta \vec{k})^2}{2 m^*} = \frac{k_F^2}{2 m^*} + \frac{k_F \delta k}{m^*} + \frac{\delta k^2}{2 m^*}$.
You can then throw the $\delta k^2$ part because it is second order, $\frac{k_F^2}{2 m^*} = E_F$ is the Fermi energy which you take as a reference, and using the fact that $p_F = \hbar k_F$ you get the desired formula.
