Assume that you have a wet shirt that you have just washed. You squeeze of the surplus water that can be squeezed out.
Method 1:
1)You iron the shirt for 5 minutes and then hang it out to dry out in the warm sunshine (morning sun) for 15 minutes and examine it.
Method 2:
2)You first hang it out in the sunshine for 15 minutes and then iron the shirt for 5 minutes (same heat setting) and then you examine it
Which of the above two methods is better for drying the shirt faster?
(If you need more data:
1)Assume cotton shirt 2)Assume that the wet shirt is not dripping water 3)Assume ambient temp is at 35 deg Celsius 4)Assume that it is not a windy or a cloudy day)
Sidarth
  • 1,007
