So according to my notes, the field inside a conductor is zero. But what, exactly, is meant by inside?
I think we are in electrostatics for the purpose of this question.
The reason it is zero is because all the electrons are pushed to the edge of the conductor. So are these electrons assumed to be no longer inside the conductor (i.e. not strictly inside the conductor). If this is the case, does this mean that Gauss' Law applies to charges strictly inside a surface, and considers charges on the surface to be "outside" the surface, or more precisely, not strictly inside the surface?
Please let me know if I should write this more clearly.
physics
The basic idea, at least as it is taught to the freshmen is as following:
In conductor you have plenty of electrons that are practically "free". You are interested in electrostatic situation, that is the situation in which all electrons are by definition practically still. This is possible only if electric field within conductor is zero. If that would not be so, there would exist electric force
$$\vec{F} = q \vec{E} = m \vec{a}$$
end electrons would accelerate.
By using Gauss law, you can prove, that the core of the conductor is actually charge neutral. Imagine that you make a Gauss surface that encloses all but surface of the conductor (i.e. Gauss surface is only tiny fraction smaller than surface of the conductor). Since electric field on the whole Gauss surface equals zero, that means that
$$\frac{Q}{\epsilon_0} = \int \vec{E} \cdot \text{d}\vec{A} = 0,$$
that is total enclosed charge $Q$ equals zero.
So we came to the final conclusion, which obviously claims that any excessive positive or negative charge (if such exists) must be on the surface of the conductor. Electric field can be (and actually usually is) larger than zero on the very surface of the conductor. This is because electrons, even if they are pushed out by electric field, cannot leave the material, they are not "free" to do that.
Generally all this idea of electrostatics seem to be a bit "over edge", isn't it? Well as it turns out electrons need only a fraction of a second to realign themselves in such a way that electrostatic situation is satisfied. So electrostatic situations are real.
Pygmalion
  • 5,003
Adding a bit of detail to Pygmalion's answer (at the risk of going down a rabbit hole):
1) The math definition of an "inside" point is that it is surrounded by other "inside" points, so the surface is not inside. (I like your "not strictly inside".) However, the surface charge electrons are still part of the conductor, and they can and do adjust so that the conductor surface is an equipotential (tangential electric field = 0). (In short, the conductor is composed of its inside plus its surface, and these two sets are disjoint.)
2) Gauss' law $\nabla \cdot E= \rho$ applies everywhere: in its differential form, $\nabla \cdot E=0$ both inside the conductor (where $E=0$) and outside. On the surface the divergence is non-zero (in fact a nasty discontinuous delta-function-type thingey). More tractably, you can use the integral version and consider Gaussian pill-boxes with one side inside and the other outside. I am not responsible if you put a pill-box side precisely on the surface.
Art Brown
  • 6,121
