Formula for calculating speed of sound in dry air is
$$V(t)=V(0)+0.61t$$
The temperature here is always taken in Celsius .Why don't we use kelvin?
$$V(t)=V(0)+0.61t$$
The speed of sound in an ideal gas is given by:
$$ v = \sqrt{\gamma RT} $$
Suppose we want to calculate the speed near some reference temperature $T_0$, i.e. the temperature is $T = T_0 + \delta T$ where $\delta T$ is small. We rewrite the equation for the velocity as:
$$ v = \sqrt{\gamma R(T_0 + \delta T} $$
and then rearrange this to:
$$ v = \sqrt{\gamma R T_0} \left(1 + \frac{\delta T}{T_0}\right)^{1/2}$$
Then because $\delta T \ll T_0$ we can expand the square root using a binomial expansion to get:
$$ v \approx \sqrt{\gamma R T_0} \left(1 + \frac{1}{2}\frac{\delta T}{T_0}\right) $$
But the term $\sqrt{\gamma R T_0}$ is just the velocity at the temperature $T_0$ so our equation becomes:
$$ v \approx v(T_0) + \frac{1}{2}\sqrt{\frac{\gamma R}{T_0}}\delta T $$
and that's how we get the approximate equation you cite. The particular case when $T$ is given in Celcius just comes from taking $T_0 = 273.15$K so there is nothing special about it - it's just a convenient choice of $T_0$.
