15
Resistance is given by $\rho L/A$, where $\rho$ is the material constant, $L$ is the length, and $A$ is the area.
Is there any way that this can be derived mathematically, or is the only way experimentally?
Personally, I think experiment is the only way as I do not know how you would get $\rho$ otherwise.
David Z
  • 77,804
There is actually a student-friendly microscopic model how to derive the real Ohm's law
$$\vec{j} = \sigma \vec{E}.$$
After its derivation you can transform it into the more common form using the answer by Nesp.
The idea goes as following:
We must start with the definition of current:
$$I = \frac{\Delta Q}{\Delta t}.$$
So where does current come from? Current is the result of movement of charged particles in the material. Obviously, current will be proportional to the charge of one particle, the speed of the particle and the total number of particles. Current density $\vec{j}$ can therefore be written as
$$\vec{j} = N q \vec{v}_\text{d},$$
where $N$ is the density of particles, $q$ is the charge of one particle and $\vec{v}_\text{d}$ is the drift speed, that is average speed of particles. I think that this definition is self-explanatory, but it can also be derived more strictly from the second formula.
In material you have certain amount of almost "free" electrons. Those electrons behave like particles in the gas, they are crashing between themselves and into atom cores, bouncing back and forth and there is actually no net movement, average speed and current are zero.
However, if you put some potential on the ends of material, you actually put homogenous electric field in the material, which strength is
$$E = \frac{V}{l}$$
All electrons start accelerating in the direction of the positive potential and you can easily obtain this acceleration using the expression
$$\vec{a} = \frac{\vec{F}}{m} = \frac{q\vec{E}}{m}.$$
So you actually get net movement of electrons. And now comes the beauty of Ohms law. You should ask yourself: If electrons accelerate, how come current (which is proportional to average speed of electrons) isn't becoming larger and larger with the time?
The reason is that electrons keep crashing into atom cores and after those crashes their speed is by average reset back to zero! So let's define some typical time between two crashes $\tau$. The average maximum speed of electrons between two crashes shall be
$$\vec{v}_\text{max} = \vec{a} \tau = \frac{q\vec{E}}{m} \tau.$$
Obviously, average speed between two crashes, which equals drift speed is half of that value.
From the definition of current density you finally obtain
$$\vec{j} = N \frac{q^2 \tau}{2 m} \vec{E}$$
which is Ohm's law.
Therefore - and this is direct answer to your question - conductivity is
$$\sigma = \frac{1}{\rho} = N \frac{q^2 \tau}{2 m}$$
and can be determined by knowing the mass and the charge of electron, density of free electrons in the material and the average time between two crashes.
By the way: these crashes between electrons and atom cores actually adds heat to material (increases temperature), so this microscopic model explains everyhing.
Pygmalion
  • 5,003
The answer is "yes", if you take for granted that $R$ is defined by the relation $\Delta V=IR$. In fact it is derived from (the real) Ohm's Law.
Ohm's law states that, for some materials (the so-called "Ohmic" materials) the current density vector $\vec{J}$ (current per unit area) is parallel to the electric field $\vec{E}$, i.e., $$\vec{J}=\sigma\vec{E}=\frac{1}{\rho}\vec{E}\ \ \ \ \ \ \ (1),$$ where $\sigma=1/\rho$ is the conductivity of the material (which is the inverse of $\rho$, the resistivity), which can be considered a constant for some materials (but is not restricted to be constant in general). From here, consider a material of length $L$ which has two extremes of area $A$ where we apply a potential difference $\Delta V$. Using the definition of the potential difference, it is easy to show that $$|\vec{E}|=\frac{\Delta V}{L}\ \ \ \ \ \ \ (2).$$ On the other hand, we can express the current flowing trough the material, from the definition of current density as $$|\vec{J}|=\frac{I}{A}\ \ \ \ \ \ \ (3).$$ Using, then, the results of equation $(2)$ and $(3)$ on equation $(1)$, we get $$\frac{I}{A}=\frac{1}{\rho}\frac{\Delta V}{L},$$ or, $$\Delta V=I\frac{\rho L}{A}.$$ On the typical relationship, $\Delta V=IR$, then $R=\rho L/A$.
Néstor
  • 430
One fundamental
Well, if you consider $V=IR$ as fundamental (and not $\bf J=\sigma \bf E$--IMO this is the actual Ohm's law), then you can derive it by what I call "discrete calculus"
Taking the definition of resistivity as "resistance per unit length and unit area":
Take a cuboid of dimensions $L,W,H$ along coordinate axes $x,y,z$. Current flows along $x$. Let $\delta x,\delta y,\delta z${*} be unit elements. We cannot use calculus here as we do not yet know that resistivity is to be multiplied by length but divided by volume.
Now, lets take a horizontal "pillar" at $y,z$, of area $\delta y\delta z$. This pillar is divided into $\frac{L}{\delta x}$ parts (which is equivalent to $L$ parts--since $\delta x$ is a unit quantity--but this gets us a dimensionless constant).
So, we have $\frac{L}{\delta x}$ tiny cubes of resistance $\rho$ (unit dimensions, right)? They are in series, so total resistance is $\rho\frac{L}{\delta x}$. Lets call this $\delta R$
Now, we have $n=\frac{WH}{\delta y\delta y}$ such "pillars", of resistance $\delta R$, all in parallel. Since they have the same resistance, we can just divide $\delta R$ by $n$ to get total resistance.
$$\therefore R=\delta R/n=\frac{\rho L \delta y \delta z}{WH \delta x}$$
We can absorb the $\delta$ terms into $\rho$, since initially we took $\rho$ to be of dimensions of resistance. Now we can just rewrite it to have dimensions of resistivity (which we "did not know" initially). Also, $WH=A$(area).
So, $R=\frac{\rho L}{A}$
Both fundamental
If you consider $\bf J=\sigma \bf E$ or $\rho \bf J= \bf E$ as fundamental as well as $V=IR$, then we can derive the formula:
$E=V/L$, since we're considering uniform cuboid
$J=I/A$ by definition
$\implies \rho I/A=V/L\implies V=I\left(\frac{\rho L}{A}\right)$
Comparing with $V=IR$ we get $R=\frac{\rho L}{A}$
Arbitrary
Remember that resistance ad resistivity are sort of arbitrarily defined concepts. Resistance is "ratio of p.d. and current", resistivity is either "resistance of unit area and length", or "ratio of electric field and current density magnitudes".
My first proof sort of tries to do away with as much arbitrariness as possible.
*This is just me having fun--I rarely get to use the quirky lowercase delta :)
Manishearth
  • 19,167
  • 64
  • 104
