I think I have understood gyroscope in terms of angular momentum and how the torque of gravitational force moves it the way it does.
Also I understand the direction in which it would move: What determines the direction of precession of a gyroscope?
And the working : https://physics.stackexchange.com/a/226485/102169
I saw a couple of videos about it: https://youtu.be/ty9QSiVC2g0
https://youtu.be/GeyDf4ooPdo
Note how the wheel rotates around. So the Centre of Mass of the wheel goes around the wheel in a horizontal circle. Which force acts on the system of Rod and the Wheel that makes it perform circular motion?
I see it analogous to a particle performing circular motion or a rod being rotated about one of its end (a compound system).
Since the string attached would only pull it up, I understand why it doesn't fall off against gravity but why does it perform circular motion without a centripetal force?
Is anything wrong in my analogy? Or is there a force I don't see?
The point about which the gyroscope pivots provides the centripetal force: this is either friction, or some hinge mechanism.
Floris
  • 119,981
