First, a bit of background. I'm a chemist who works with synchrotron-based techniques, but I'm focussed on materials analysis rather than synchrotron physics.
I'm struggling to work out where synchrotron radiation (SR) actually comes from. Why does subjecting an electron to radial acceleration cause it to emit photons? I understand, with Bremsstrahlung radiation that the energy from the decelerating particle has to go somewhere. My first thought was that SR may arise from a similar effect, as my understanding is that you do work when you radially accelerate a particle. I reasoned that, since the magnitude of its velocity remains constant, and the magnitude of the kinetic energy (KE) remains constant, SR must result from conservation of energy (i.e. the work done in the radial acceleration is converted into SR). However, I've since read that emission of SR causes the electrons in the storage ring to lose energy. And, this energy must be resupplied by the inclusion of RF cavities in the ring. This would suggest that SR comes from the KE of the electron, not from the work of the magnet on the electron. (On reflection, I can't see how a permanent magnet could "do work".)
So why is SR emitted?
(Please bear in mind, that as a chemist, I have next to no knowledge of relativity, electrodynamics, Maxwell's equations, etc. I'm really just looking for a conceptual understanding. I don't mind a mathematical answer if you can give one without assuming knowledge of such physics. But, I imagine that's unlikely.)
Edit: Any good textbook recommendations would be helpful too. All the books I've read either gloss over the issue or use physics that goes over my head.
