Is the actual energy of a photon ever measured? How is it done?
I read that a photon is usually identified by diffraction, that means its wavelength is measured, is that right? In this way we determine that a red-light photon makes a full oscillation in roughly $700 nm$Then, by theoretical reasons, we deduce its energy is about $400 THz$. I wonder if, when this relation was established, ther was an instrument capable of precisely counting $4*10^{14}$ oscillations in an exact second.
What I am trying to understand is what exacly is a photon, when we can talk about the existence of a photon. I'll try to explain what is my problem:
we usually receive light (or radio waves) from a continuous source: the Sun, a flame, a bulb etc..., right? how/when can we isolate a single photon? Is a photon the whole set of oscillations during the span of a second? can we consider a photon of red light a single oscillation of the EM field lasting only $\frac{1}{4*10^{14}}$ second, even if no instrument would be able to detect it? Yet, that photo would propagate all the same at $c$ in vacuum for a second or more or forever, but, though its wavelength its still $700 nm$, its energy would probably not be in the region of THz anymore, or would it? To frame it differently, does energy change if the unit of time is halved or doubled?
I hope you can understand my questions even though my exposition is confused.
Edit
The energy of anything is a definite issue, it is the result of a meaurement, and does not depend on theoretical considerations, QM, classical or other models, or onthe fact whether it is a wave or not.
I'll try to clarify my main concern with a concrete example: consider something you can control and manipulate. You can produce low frequency EMR (short radio wave about 10m wavelength) making a charge oscillate up and down 30 million times a second, right?
Now, suppose you make that charge oscillate only for 1/1000 th of a second. all the same That wave will propagate at C and will oscillate 3*10^7 times a second and will be diffracted revealing a wavelength of 10m, is that right or will it oscillate only 30 000 times a second?
Furthermore, whenit hits something or you determine its frequency, will it still have the same energy of a wave that has been produced making a charge oscillate for one whole second or for ten seconds?
5 Answers5
The classical light beam, an electromagnetic wave, emerges from zillions of photons which travel with velocity $c$ and build it up.
The energy of a photon is $E=h\times \nu$, where $h$ the Planck constant, and $\nu$ is the frequency which will appear in a classical wave built up by this energy photons. The way this happens is explained mathematically here, but is not simple to understand without quantum mechanics and field theory. The photon itself is not oscillating in (x,y,z,t). Only travelling with velocity $c$.
The energy of the classical wave is given by the average intensity, for example , for a plane wave it can be written
$$S=\frac{1}{c\mu_0}E^2\overline{\sin^2(kx-\omega t)}=\frac{1}{c\mu_0}\frac{E_m^2}{2} $$
where here $E$ is the electric field of the classical light wave.
The individual energy of $h\nu$ of photons will add up to the energy transferred by the collective electromagnetic wave.
The velocity of the photon is fixed and does not change unless there is an interaction, as in Compton scattering,. It is an elementary particle of the standard model .
The theoretical model, called quantum electrodynamics, is so well validated with experimental data that one can identify the energy of the photon with the frequency of the classical light beam, and use classical interference set ups. Individual photons from known frequency light beams have been observed through the double slit experiment, as dots on a screen. The existence of photons and their frequency with energy association is well validated.
When energies become large , as in X rays and gamma rays, different laboratory techniques can identify the energy of a single photon, as with the photoelectric effect, and with the electromagnetic calorimeters in particle experiments identifying single gamma rays of great energy.
For example this Higgs to gamma gamma event:
higgstogammagamm
The green lines display the energy deposited in the calorimeters by each gamma. It is known as a photon because it does not interact in the tracking chambers, and deposits the energy in the electromagnetic ones.
so to your questions
Yes, as seen above.
Is a photon the whole set of oscillations during the span of a second? can we consider a photon of red light a single oscillation of the EM field lasting only 1 second/ 4*10^14 second
No. as said the photon is an elementary particle and the classical light beam rides on zillions of photons , each contributing in synergy a tiny part to the electric and magnetic fields of the electromagnetic field.
No the energy of the photon is always equal to $h\nu$, for the whole spectrum. $ν$ is just there for a photon only as a handle to inform what type of light beam a zillion of such energy photons will generate, see the table.
There is a mathematical quantum mechanical connection between the classical electrodynamic solutions and the quantum mechanical solution, because maxwell's equations are quantized and give rise to the wavefunction of the photon. In the wavefunction, which is complex, i.e not measurable, there are the same E nd B and $ν$ that will be built up by zillions of photons. This is the frequency appearing in the double slit experiment , one photon at a time. It is in the probability of detection of the photon that the frequency plays a role.
You ask in a comment:
if you oscillate a charge 3000 times in 1/10000 of a second you get a photon that discharges $3\times 10^7\ h$ of energy when it hits something
The units are not understandable, but no, an oscillating charge will not give one photon, it will depend on the boundary values and will give a spectrum of classical frequencies which will be composed of innumerable photons.
anna v
  • 236,935
The easiest way to measure the energy of a photon, is to make a reaction using the photoelectric effect. The photon hits a surface, knocks out an electron, and the electron can be prevented from carrying charge away from the surface by putting a small attracting voltage onto that surface (this is called the 'stopping potential').
It is an experiment usually carried out with a vacuum phototube, and a LOT of photons, all of the same energy (color). You can adjust the stopping potential until the phototube doesn't generate any current when illuminated. The stopping potential (voltage) multiplied by the charge of an electron is the estimate of the photon energy (there's some corrections for the material of the phototube, and it doesn't work well on low-energy photons).
Whit3rd
  • 10,853
It is convenient to use wavelength as a unit of measurement when it comes to photons but really it starts with the frequency that the photon is oscillating at. We know the speed of light and if you diffract it from one surface to another we can measure the distances using Pythagorean's Theorem to determine the frequency or wavelength. A photon oscillating at 400THZ and traveling along at the speed of light will complete one oscillations every 700 nm. The energy (frequency) of a photon does not change if the unit of time is halved or doubled? Wavelength is not a wave, its just the distance a photon travels in one oscillation. The speed stays the same and if the photon has less energy (lower frequency) then the so called wavelength will be longer.
Bill Alsept
  • 4,159
I think you get confused because you try to picture a photon in a classical framework. There is (unfortunately) no accurate way of explaining what a photon is without the use of quantum mechanics. A photon is much more complicated than just "a set of oscillations during the span of a second" : it is in essence a quantum of excitation of the electromagnetic field in the vacuum. I know it might sound a bit technical, but you need the framework of quantum field theory (more precisely, quantum electrodynamics) to fully understand the nature of the photon.
There are number of classical experiments that were reconducted in a "quantum way" that might give an awnser to some of your (very legitimate) doubts on the topic. For instance, many versions of the famous Young's double-slit experiment have been studied with single photons, or in other complicated situations that reveal the quantum nature of light.
Dimitri
  • 2,569
I worked on the firmware of the femtosecond laser Maitai. Each pulse of light last approximatively 20 fs. The infrared light at 800 nm has time to complete about 100 oscillations.
The repetition rate is 80 MHz. The duty cycle is 1/1000 so given a mean power of 2.5 watts, the intensity of the light pulse is equivalent to 2.5 mega watt.
My understanding is that a single photon is actually one sinusoidal oscillation starting at zero, going up to reach positive peak, going down to negative peak and returning to zero.
Fourier analysis tells us that such wave shape would need a large (infinite) number of harmonics to generate using the sum of sinusoidal waves which extend in the past and future indefinitely. That is where quantum physics intervene, allowing one electron to absorb a single oscillation and instantaneously jump to one or more energy level.
The equivalent with sound wave would be, suppose a bunch of guitar laying of tables and I produce a sound wave at 441 Hz. If the first guitar is well tuned, it would only capture a wave at 440 hz. The next guitar happen to have one string imperfectly tuned so that it's resonant frequency happen to be 441 Hz. That string would capture all the energy of the sound wave and start vibrating while all the other string of that same guitar would detect nothing. And all the other guitar around would not perceive any air molecule vibration because the entire wave energy has been entirely absorbed by the string on the second guitar.
The energy of a photon correspond to the frequency which can be measured with prism, an optical equivalent of a FFT. The photoelectric effect is another way to measure the energy using a blocking voltage as described in another answer. The wavelength, of course, change with propagation speed.
