The first law applied to a liquid film is $dU = dQ +2\sigma dA$ where $\sigma$ stands for surface tension.
Or $dQ = dU + (-2\sigma) dA \leftrightarrow dQ = dU + PdV$
Now suppose we wish to find what happens to temperature if I increase the area adiabatically. (Throughout I assume the stretching to be reversible.)
i.e. we need to know $\left(\frac{dT}{dA}\right)_S$
I propose two methods here to calculate this.
Method 1 (quite straight-forward)
Clearly for adiabatic processes $dQ=0$ i.e. $dU = 2\sigma dA$. Here $dU=C_A dT$. So, we get $dT = \frac{2\sigma}{C_A} dA$
Or $\left(\frac{dT}{dV}\right)_S = \frac{2\sigma}{C_A}$
Method 2 (uses Maxwell relations)
As we know following Maxwell relation, $\left(\frac{dT}{dV}\right)_S = - \left(\frac{dP}{dS}\right)_V$
which in our case would correspond to $\left(\frac{dT}{dA}\right)_S = 2 \left(\frac{d\sigma}{dS}\right)_A = 2T \left(\frac{d\sigma}{dQ}\right)_A$.
Also $(dQ)_A = (dU)_A = C_A dT$
This would mean $\left(\frac{dT}{dA}\right)_S = \frac{2T}{C_A} \left(\frac{d\sigma}{dT}\right)_A$
My teacher says that it is the second method which is correct, but I can not figure out why first one is wrong since both can not certainly be right together.
