A post (below) on the Bishop Hill blog relating to climate change asserts that no warming effect can be attributed to $\mathrm{CO_2}$. I don't know whether the author is really a physicist but it sounds impressive (Planck spectra and black-body radiation etc). Can someone explain in layman's language whether the assertions are valid.
Quote from http://www.bishop-hill.net/blog/2012/4/5/greenhouse-reversal.html
There is no greenhouse, so it can't be reversed.
Many so-called skeptics are not really basing their arguments on the true
physics of the atmosphere. By failing to do so, they are demonstrating
that they also have fallen for the IPCC bluff that radiation from a cooler
atmosphere (including so-called backradiation, but also initial radiation)
can transfer thermal energy to a warmer surface.
This is not correct physics and the sooner this is made clear to the
public the better. True physics, backed up by basic phenomena such as the
fact that radiation in a microwave oven is not absorbed in the usual sense
of the word, shows why this is the case. No one has ever proved anything
to the contrary in any empirical experiment, and never will.
The only thing any such radiation from the atmosphere can do is slow down
that third or so of surface cooling which occurs by way of radiation that
does not escape to space via the atmospheric window. Radiation from the
atmosphere can have absolutely no effect on evaporative cooling, chemical
processes or sensible heat transfer. These non-radiative components plus
the radiation to space make up about 70% of all surface
cooling. Furthermore, the effect of carbon dioxide with its limited
frequencies is far less than a true blackbody, and less per molecule than
water vapor. No gas can radiate outside its Planck spectrum (i.e. more than
a true blackbody) and so there is no way that carbon dioxide (1 in 2,500
molecules) can contribute a very large amount of radiation anyway.
The other cooling processes merely accelerate and compensate for any
minuscule slowing of radiative cooling. Thus there is absolutely no
warming attributable to carbon dioxide. It is time for skeptics to get
their facts right and stop giving in to part of the hoax. Only truth will
prevail in the long run.
EDIT: The author of the blog post was 'Doug Cotton', who has published a related paper at http://principia-scientific.org/publications/psi_radiated_energy.pdf and has a website at http://climate-change-theory.com/
