27
The question is about why analytical continuation as a regularization scheme works at all, and whether there are some physical justifications. However, as this is a relatively general question, I shall use the following examples to make the question more concrete.
Let us consider the Casimir energy first, which is usually the first place in QFT where the notion of regularization shows up. In the calculation of Casimir energy, one encounters the sum $\sum_{n=1}^{\infty}n$ and to regularize it, one way of doing it is to use zeta function regularization, i.e. by writing $\lim_{s\to 1}\sum_{n=1}^{\infty}n^{-s}$, and then use Riemann zeta function, as an analytical continuation. Different from other regularization schemes(such as hard cutoff, attaching a regulator, whose pole term could be cancelled by adding counter terms in the Lagrangian), it seems that this does not have a physical picture behind it. Moreover, different from the other two methods, there is also ambiguity in the answer: One can simply change it to $\lim_{s\to 0}\sum_{n=1}^{\infty}\frac{n}{(n+\alpha)^s} $, where $\alpha$ is a free parameter. Thus one can analytical continue it to $\zeta(-1,\alpha+1)-\alpha\zeta(0,\alpha+1)=\frac{1}{2}\alpha^2-\frac{1}{12}$, which gives $-\frac{1}{12}$ when $\alpha=0$, but in general a polynomial of $\alpha$. Note this term remains in the Casimir force because $\alpha$ has no $r$ dependence a priori.(1-d as an example, $E(r)=\frac{\pi}{4r}(\alpha^2-\frac{1}{6})$). Thus it seems with zeta function regularization that we can only give some lower bound of the magnitude of the force instead of the force itself.
Casimir's energy is not observable. So maybe one might think the problem is not so serious. However, let us consider another example- in AdS/CFT correspondence, one has, roughly speaking, $Z_{CFT}=Z_{AdS}|_{boundary}$ so that $F_{CFT}=F_{AdS}|_{boundary}$, where $F$ is free energy. The claim does not make sense at the first sight as naively speaking one can always shift energy by a constant. However, both theories in AdS/CFT are supersymmetric so one could no longer arbitrarily shift the Lagrangian by a constant. In this context $F$ is rigid. However, calculation of $F$ again involves regularization(such as when computing one loop determinant, summing over Klauz Klein levels, or something similar such as section 3.5 of this paper), and if one uses Hurwitz zeta to do analytical continuation, the above arbitrariness is still there.
(Maybe one would expect that some regulators are compatible with super-symmetry and some are not, and in this way the answer becomes unambiguous. But I haven't seen any discussions like that. )
user110373
  • 1,429
