From the equation $E_k=\frac12mv^2$ you can determine more energy is necessary to accelerate a mass the higher your initial velocity is. For example, three times more energy is necessary to accelerate a mass from 1 m/s to 2 m/s than from 0 m/s to 1 m/s. If the earth is moving in the universe, what is our standard frame of reference? Why?
Thanks in advance for your time and answers
DanielSank
  • 25,766
The energy required to accelerate an object by a given velocity increment is linear in the initial velocity in the non-relativistic limit (where $E_k=\frac{1}{2}mv^2$ applies). It is even more energy intensive for the relativistic case when the velocity of light (c) is approached. That is because the relativistic expression for kinetic energy is: $$E_k=mc^2(\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}-1)$$.
Here is a site that should clarify both the relativistic and non-relativistic cases if you make use of the available links. http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/releng.html For your last question see the comments by @CuriousOne and @navigator above.
Lewis Miller
  • 6,162
  • 19
  • 27
