I want to give you an example to my question:
When you spray some pressured gas on a surface, liquid water for example, the surface could freeze. but why..
As far as I know molecules close to each other are on a high energy level, which explains the higher temperature under pressure ..it wants to expand because all molecules prefer a lower energy level.. so when expanding, the gas loses some of it's overall energy.. but wouldn't that also mean the surroundings would be heated instead of being cooled down since the lost energy of the gas would be transferred to it? Is it maybe because the gas takes energy to expand? But then, why does it want to expand if it takes energy to do so?
I know this is a little mess of thoughts and might seem simple to you, but I hope you can find an answer for a non-physicist.
The situation I think you're talking about is a hand-held spray can like hair-spray. There is the stuff they're trying to move, the paint or hair gel or whatever, and a carrier-gas. Now in order to save money and not make the can heavy-duty, they choose a gas that is liquid at room temperature at higher-than-air-pressure (but not too high; the can must still be cheap to make.) The liquid and gas co-exist at that temp and pressure. However, if you lower the pressure (by releasing some gas) the liquid starts turning into gas (boiling). The action of boiling requires the input of energy (the heat of vaporization), which comes from the thermal energy of the liquid, that is, it gets cold. Cold liquid gives off cold gas.
Eventually, the liquid gets so cold that it doesn't boil at standard pressure and the can stops working until you let it warm up again.
The heat of vaporization can be very high. Our experience with water shows this. The time it takes a pot of water to reach boiling temperature is so much, but to rise one more degree, to where it's all gas, takes a long time, relative to it. This is the time it takes for the heat source to transfer the heat of vaporization to it.
Andrew
  • 167
