,I got one confusion when reading Goldstein's Classical Mechanics (page 20, third edition). After getting the equation $$ \sum \left\{\left[\frac{\mathrm{d}}{\mathrm{d}t}{\left(\frac{\partial T}{\partial \dot{q_{j}}} \right)} - \frac{\partial T}{\partial q_{j} } \right] - Q_{j} \right\} \ \delta q_{j} = 0 $$ then it says that
Note that in a system of Cartesian coordinates the partial derivative of $T$ with respect to $q_{j}$ vanishes. Thus, speaking in the language of differential geometry, this term arises from the curvature of the coordinates $q_{j}$. In polar coordinates, e.g., it is in the partial derivative of $T$ with respect to an angle coordinate that the centripetal acceleration term appears.
My question is: Is the above statement general, i.e., that the kinetic energy $T$ does not depend on the position. I wonder why velocity can't depend on the particle's position vector. I mean, why couldn't we have cases where $\vec{v} = \vec{v}(\vec r ,t)$, so that the kinetic energy depends on $q_{j}$ or $\vec{r}$?
I will use the example of the second answer in this post What is the difference between implicit, explicit, and total time dependence, i.e. $\frac{\partial \rho}{\partial t}$ and $\frac{d \rho} {dt}$?
the second answer,
suppose we have a velocity distribution of gas whose function is $\vec {v}=\vec {v}(x,y,z,t)$
then the partial derivative with respect to $x$ is
$$\frac{\partial T} {\partial x}=mv\frac{\partial v} {\partial x}$$
since $v$ depends on $x$, I think in this case. $\frac{\partial T}{\partial q_{j} }$ does not vanish.
FaDA
  • 657
Note that you are calculating the PARTIAL derivative with respect to $q$, you must consider anything that is not $q$ ( $\dot q $ may implicitly depend on q and t but that doesn't matter when taking the partial derivative with respect to $q$) is just considered a constant, thus its partial derivative vanishes. I can't tell you more, it's just the properties of the partial derivatives, I suggest you get a good book on calculus and do a lot of exercises.
It is the same thing when you work out the Euler-Lagrange equations, $\dfrac{\partial L}{\partial q} = \mathrm{Force(q)}$, because you consider T a constant (as it doesn't explicitly depend on position but on velocity)
Suriya
  • 1,768
The only way that quote makes sense to me is if he assumes his conclusion. He must have written some constraints on the allowed forms of kinetic energy.
Emil
  • 713
The author says, in Cartesian coordinates (denote them $x$, $\dot{x}$), kinetic energy does not depend on the second derivative of the coordinate. This is a general statement about Cartesian coordinates, not any coordinate system.
Thus, if $T$ depends on $q$, it is solely because it is, in a sense, non-Cartesian --- i.e., curvilinear. Hence this argument is made from the stance point of differential geometry, an unnecessary digression that the author made.
Arthur
  • 51
