28
As far as I'm aware, there are no quantum gravity theories that deal directly with closed timelike curves. Some of them (like canonical quantum gravity, causal dynamical triangulation and loop quantum gravity) forbid them outright, others merely seem to not discuss the topic. I've found quite a variety of QFT behaviour in classical spacetimes with closed timelike curves, including string theory in a CTC background, but I can't really think of any paper where the metric wavefunction (or sum of metric histories or whatever else) might run over acausal states.
The obvious candidate for this would be one of the variant of path integrals like Euclidian gravity, Lorentzian gravity, Regge calculus, etc. But there seem to always be this assumption that the boundary conditions (if present) will always be on spacelike hypersurfaces, which, while it does not make it impossible to have closed timelike curves on such spaces, certainly restricts their numbers (I suspect that CTCs in such a case only arises from the topology and not the metric).
String theory might also work out, as I am not aware of any theorems forbidding the strings to reduce to CTC solutions in the classical limit, but I do not know that much about string theory unfortunately.
Are there any papers discussing such topics? Are they even possible in the context of any of those theories as we currently understand them?
Slereah
  • 17,006
Exotic objects known as "negative branes" can be constructed (at least perturbatively) within string theory. Once they are introduced, many exotic aspects of timelike compactification, closed timelike curves or even "emergent timelike directions" can be studied. The relevant paper is Negative Branes, Supergroups and the Signature of Spacetime. For an overview see this talk.
This doesn't directly answer your question, but there is a small literature on the quantum mechanics/information of CTCs. A seminal paper from the 90s is "Quantum mechanics near closed timelike lines" by David Deutsch. More recently (2009), Scott Aaronson and John Watrous used similar methods to show that CTCs make classical and quantum computing equivalent. Deutsch and successors require that the CTC input state is a fixed point of the unitary operator associated with going through the CTC. This is called the "causal consistency framework". They plug the CTC into a quantum circuit, use the fixed point properties, and see what happens. If you don't like CTCs, you can view these efforts as counterfactually probing what goes wrong.
This can be connected to quantum gravity in the following "low-tech" way. Say $X$ is your favourite theory of quantum gravity. If CTCs $\Rightarrow$ stuff, but $X \not\Rightarrow$ stuff, then $X \not\Rightarrow$ CTC. No CTC for you! Of course, showing that $X \not\Rightarrow$ stuff is likely to be hard, and I'm not aware of any papers that follow this outline.
-8
Do any quantum gravity theories deal with closed timelike curves?
No.
As far as I know that's correct.
Some of them (like canonical QG, CDT and LQG) forbid them outright, others merely seem to not discuss the topic.
For good reason: closed timelike curves are not what most people think. There's a number of issues within general relativity which are magnified in quantum-gravity theories, some of which have been kicking around for decades, and none of which have proven at all successful. For good reason, but that's one for another day. What isn't, is that a closed timelike curve is an abstract thing. The important thing to understand is that you don't travel around it. Instead blood moves through your body, electrochemical signals move through your brain, the Earth moves, light moves through space, and so on. Your worldline is an abstract imaginary depiction of motion through space in a static 3+1 dimensional "block universe" called spacetime. It's like I throw a red ball, and you film it then you develop the film and cut it up into individual frames and form them into a block. The red streak in the block is akin to the ball's world-line. But the ball is not moving up that red streak, and in similar vein you don't travel along your worldline. Objects don't move through spacetime, objects move through space. The misconception that they do move through spacetime along a worldline probably stems from Wheeler. See A World Without Time: The Forgotten Legacy of Gödel and Einstein, where author Palle Yourgrau says Wheeler conflated a circle with a cycle, "precisely missing the force of Gödel's conclusion":
Nor can I.
We live in a world of space and motion. Worldlines are abstract things that don't actually exist, nor do light cones, nor do spacelike hypersurfaces, and nor do closed time-like curves. Try to think what a CTC really is: it isn't something you can travel around, GR doesn't allow for time travel. If your world-line really was some closed timelike curve that was 24 hours long, your life lasts for 24 hours, and it is causeless. It's like some SciFi Mayfly Day. You are born from an egg, you live for a day, you lay the egg, you die. And that's it. There is no repetition, it isn't like Groundhog Day, because you don't travel along your worldline.
Forget string theory. It's a mathematical fantasy that has gone nowhere for fifty years.
You can always find something, see the arXiv for example. But I wouldn't waste my time with them if I were you. Instead you'd be better off spending more time on GR and understanding why CTCs are science fiction. Pay more attention to the Einstein digital papers, and less attention to Kip Thorne.
John Duffield
  • 11,381
