Why do no particles have a 1/3 spin? Why are all particles' spin either a half-integer or integer? How would a particle with such a spin behave, as a fermion, boson, or neither?
tox123
  • 588
This is not my answer, it's one of the answers you can find here
Is there a reason why the spin of particles is integer or half integer instead of, say, even and odd?
I just wrote here (and re-posted) the work of @Siva which I found a very good answer. However, follow the link to read more interesting useful answers
The "spin" tells us how the wavefunction changes when we rotate space (or spacetime). Just because I double all charges by convention, the behaviour of the wavefunction will not be any different. What will happen is that the "doubling" or charges will lead to the "halving" of your definition of angles such that the physical results (which depends on angle multiplied by spin) remain the same.
Wrt. the observation on "odd" and "even" functions -- that is not an accident and it works quite like you think it does.
The crux of the matter is that a "full rotation" corresponds to $2 \pi$ so the phase picked up by a spin $\frac{1}{2}$ wavefunction is $e^{i \pi} = -1$.
Recall that (even in classical mechanics) "angular momentum" is the generator of rotations. So if I start using different units, eg: $\tau \equiv 2 \pi$ to represent a half rotation (instead of $\pi$) then the values of charge will halve to maintain the value of $e^{i q \theta}$
If you understand some representation theory, here goes:
  1. Representations of $SO(3)$ have integer charges. Since we're referring to the group of rotations, we call that charge as "angular momentum" or "spin". The representations correspond to scalars (spin 0), vectors (spin 1) and tensors (in general of spin 2 or higher).
  2. $SU(2)$ is a "double cover" of $SO(3)$ so representations of $SU(2)$ can have the "charges" as $SO(3)$ representations. Thus we also get half-integer spin. The new representations correspond to spinors.
  3. When we consider quantum relativistic physics (aka QFT), all physical fields/particles must form kosher reps of the Lorentz algebra, which happens to be $so(3,1) \sim so(4) = su(2) \oplus su(2)$. So (up to the "unitary trick") reps of the Lorentz group can be written as a tensor product of reps of the left and right-handed $SU(2)$ algebras. Based on #2 above, these continue to have integer or half-integer spin.
EXVII
  • 3,783
