While trying to understand the divergence of a vector through the geometrical representation of the vector field, I found that pictures can be misleading. Even a vectors field which looks to be diverging while one observes the direction of arrows may be actually having a zero divergence (example $F(x,y,z)= \frac{(ix+jy+kz)}{(x^2+y^2+z^2)^(3/2)}$) (at points other than origin)or even a negative divergence (example $F(x,y)= \frac{(ix+jy)}{(x^2+y^2)^(3/2)}$). While trying to understand it through visualization of flux entering into and going out form a volume element at the position concerned, I found that the magnitude of the vector is represented by the length of the arrows and the direction is shown by the direction of the arrows.
  • What about the density of points (tail point of the vectors). What do they represent?
Maybe these points do not represent anything and the flux can be calculated by taking dot product of the vector with the surface elements which are parts of the total surface covering the volume element. But in that case the surface offered for incoming flux and for outgoing flux are same. So the flux only depends on the magnitude of the length of the incoming and outgoing vectors. Consider the case when the vectors away from the origin are shorter than the vectors nearer to origin as in the examples stated above. In that case the divergence will be always negative.
  • How the case of zero divergence arise then?
user103515
  • 1,069
