In Goldstein's Classical Mechanics (2nd ed.) on section 9-1 page 382, there is a discussion about finding a canonical transformation $$(q_i,p_i)\rightarrow (Q_j(q_i,p_i,t),P_j(q_i,p_i,t))$$ from a given generating function $F=F_1(q_i,Q_i,t)$. The following is written on the page:
Equation (9-11) then takes the form, $$\begin{align*} p_i\dot{q}_i-H&=P_i\dot{Q}_i-K+\frac{dF_1}{dt},\\ &=P_i\dot{Q}_i-K+\frac{\partial F_1}{\partial t}+ \frac{\partial F_1}{\partial q_i}\dot{q}_i+\frac{\partial F_1}{\partial Q_i}\dot{Q}_i \tag{9-13} \end{align*}$$ Since the old and the new coordinates, $q_i$ and $Q_i$, are separately independent, Eq. (9-13) can hold identically only if the coefficients of $\dot{q}_i$ and $\dot{Q}_i$ each vanish:
I don't understand the bold text above. How are $q_i$ and $Q_i$ separately independent? I thought $Q_i$ was, in general, a function of the original canonical coordinate variables $q_i$, thereby making it explicitly dependent on $q_i$ (not independent). Could somebody explain how these two canonical coordinate variables are separately independent?
