This question says that, at relativistic speeds, an object's increased mass will result in increased weight or gravitational force. But if we have increased mass and corresponding gravitational effects, does that mean that the object actually contains more matter? Does the increase in velocity result in an increase in the number of atoms in the object?
  1. If so, where does the additional matter come from? How is it distributed? E.g. if I drive my car at 0.9c, is there some law that decides whether the added matter goes to my engine block or to my headlights?
  2. If not:
    1. How does mass increase if there is no increase in matter? The SI system defines mass in terms of a physical artifact (or a number of atoms, according to one proposal), but Wikipedia has seven different definitions of mass, so I'm not sure which one(s) applies here.
    2. Does it make sense to ask how the added mass is distributed throughout the object?
Pedro
  • 129
Don't use relativistic mass. Not ever.
When you increase your kinetic energy, the magnitude of your momentum increases.
Your momentum is $\vec p=\vec v E/c^2$ and its magnitude increased because your total energy $E$ increased (and if you weren't already moving at the speed of light then it also increased because the magnitude of your velocity increased too but your total energy actually increased less due to your rest energy).
A force can change your momentum. It will have to do this by changing your energy and maybe your velocity (if massive by definitely changing your velocity).
In many cases what you mean by relativistic mass is just to take energy $E$ divided by $c^2$ such as $\vec p=\vec v E/c^2.$ However a big issue is that things you thought were equivalent (because they approximately were at slow speeds) need to actually be kept distinct at high speed. And there is no consistent way around this.
So how about weight? Well firstly you can just say that in the absence of any forces besides gravity it accelerates with the gravitational acceleration. Or even better, you could just say that Newton's laws hold in a frame that is freely falling with the gravitational acceleration.
That is actually how General Relativity does it. And you can do it too. For instance air floats because the pressure below it is bigger than the pressure above it by just enough to make it accelerates upwards with $1g$ in the freely falling frame. That's why it floats.
There aren't more atoms. That wouldn't make sense because someone moving will see different relativistic masses. And they can't see different numbers of atoms. Plus, just one atom could move and if it moved a tiny bit, the energy increases just a little bit, way less than the smallest atom.
Timaeus
  • 26,055
  • 36
  • 71
When an object reaches speeds of the order of the speed of light one no longer uses Newtonian mechanics, but has to use special relativity. The the E=mc^2 is unfortunately a hybrid between Newtonian and special relativity , in order to describe the effect of force on an object moving with speeds close to the velocity of light.
The basic relativistic formula to keep in mind is the one that contains the invariant mass, i.e. a mass that is invariant to Lorenz transformations and can define a matter object :
$$m_0^2 = E^2 - ||\mathbf p||^2\;.$$
A particle, a proton let us say, has a fixed rest mass, called "rest" because it is the value the energy of the proton is in the rest frame ( momentum zero). When accelerated close to the speed of light it is the energy that changes, not the rest mass. The equivalence of mass and energy is what , when working in a Newtonian frame, responds as a classical mass to forces .
No. Matter (ensembles of protons and neutrons and electrons) have a fixed rest mass and the number of constituents cannot change.
The answer leads to 2)
How does mass increase if there is no increase in matter? The SI system defines mass in terms of a physical artefact (or a number of atoms, according to one proposal), but Wikipedia has seven different definitions of mass, so I'm not sure which one(s) applies here.
It only "appears to increase" if one tries to fit Newtonian physics to the interaction, i.e. work with an $F=m\cdot a$ formula.That is why the m is qualified as "relativistic". It is the total energy that is increasing with an increase of the momentum:
$$E= mc^2=\sqrt{p^2c^2 + {m_0}^2 c^4} $$
As it is really the kinetic energy that is increasing with the increase in speed, this question is answered already.
anna v
  • 236,935
