Photon pair production in electron-positron annihilation is necessary to conserve the linear momentum. In such discussions the electron-positron pair collide with equal and opposite momentum, if they collide without the above condition then only a single photon can conserve the momentum (or two or more photons with different energies). Another question is why more than two photons are not produced in the symmetric collision of electron-positron.
DanielSank
  • 25,766
The problem is that you need to conserve both energy and momentum. This requires at least two photons that are not quite colinear. A single photon would carry too much momentum since $p=\frac{E}{c}$ for a single photon; two photons at nearly right angles provide a mechanism for conserving energy and momentum.
It is possible to find a solution to the energy and momentum equations with more than two photons; but it is not possible to find it with fewer. That is discussed in this earlier Q&A referenced by Kyle Kanos in the comments
Floris
  • 119,981
Conservation of momentum in two body scattering is simple to understand in the center of mass system. In the center of mass system the electron and positron have equal and opposite momentum. The resulting particles will have to be at least two, so that the generated momementum will add up to zero.
Wrong , a single momentum cannot conserve the momentum in the end products. There are continuous transformations from the center of mass, so at least two particles will have to appear in the lab too.
In this paper three and four photon annihilations are studied at DESY.
LEP experiments measured e+e- annihilations to an large number of particles, for example this three jet ALEPH event. It all depends on the available energy , and LEP had very high energy e+e-.
anna v
  • 236,935
