Using light cones to state that nothing can travel faster than light to me seems like a flawed argument. (I understand other reasons why the speed of light cannot be broken.) However, it seems to me as if this light cone argument, i.e where nothing can travel faster than light otherwise it would be able to affect past events, doesn't make sense because it operates on the assumption that light is the fastest thing, doesn't it? That's essentially saying nothing can travel faster than light, because light is the fastest thing. Apologies if I'm misunderstanding the argument of light cones, but in short my question is: is this argument not flawed?
See what I'm saying is: if something could travel faster than light, called "x", surely we would then call them x-cones.
Benjamin
  • 159
The Lorentz-transformation can be deduced without any assumption on the speed of light, see https://en.wikipedia.org/wiki/Derivations_of_the_Lorentz_transformations#From_group_postulates.
This calculation leaves an undetermined constant $\kappa$, giving $L(v)=\frac{1}{\sqrt{1 + \kappa v^2}} \begin{bmatrix} 1 & \kappa v \\ -v & 1 \end{bmatrix}.$ Now let's calculate the eigenvectors. We don't need the eigenvalues, so we can ignore any scalar factor. We can assume that an eigenvector has the form $\begin{bmatrix}1\\ u\end{bmatrix}$.
Now we have to solve $\begin{bmatrix}1\\ u\end{bmatrix}= \lambda \begin{bmatrix} 1 & \kappa v \\ -v & 1 \end{bmatrix} \begin{bmatrix}1\\ u\end{bmatrix}=\lambda\begin{bmatrix}1+uv\kappa\\-v+ u\end{bmatrix}=\lambda\cdot(1+uv\kappa)\begin{bmatrix}1\\\frac{u-v}{1+uv\kappa}\end{bmatrix}$.
Thus $u=\frac{u-v}{1+uv\kappa}\Rightarrow u+u^2v\kappa=u-v\Rightarrow u=\pm\frac 1{\sqrt{ -\kappa}} $.
Now we can interpret \begin{bmatrix}1\\ u\end{bmatrix} as an object moving with constant speed $u$. This special $u=\frac 1{\sqrt{ -\kappa}}$ is independent of the observer.
Experimentation and observation then shows that $u=c=\frac 1{\sqrt{ -\kappa}}$ is the speed of light.
Edit (inspired by @Timaeus): note that if for a matrix $A$ that has a positive real eigenvalue $\lambda_0$ with all other eigenvalues $|\lambda| <\lambda_0$ we can define $\vec x_{n+1} := \frac{1}{||x_n||}A\vec x_n$, Then $\lim_{n\to\infty}\vec x_n$ will be the eigenvector belonging to $\lambda_0$ (except for some very unlucky starting points.)
In other words, giving an object a series of Lorentz-boosts will bring it arbitrarily close to the speed given by the eigenvector.
As Gyro Gearloose commented Plain theoretical special relativity doesn't state that the speed of light is the fastest possible. It initially merely states that there is some limit speed
And as Gyro Gearloose answered, basic isotropy and group structures linearity and such give a fixed form with an unknown $\kappa$ and its up to experiment to determine the value of $\kappa$. But experiments give a speed constant that seems really close to $c$.
But I also want to point out that you are correct. If we found out that the photons has a small but nonzero mass then light would have $c$ as a limiting speed, just like other massive fields.
And having an invariant speed is also slightly different than having a limiting speed. The argument of causality limiting speed to the invariant speed is not related to there being anything that goes that speed.
Nope. Even if photons have mass, then there is still a constant equal to or very close to $c$ that is a frame invariant speed. We don't need there to be a thing that goes at that invariant speed. And if photons have mass then light, like everything else, goes at less than that speed.
See what I'm saying is: if somethingĀ couldĀ travel faster than light, called "x", surely we would then call them x-cones.
If photons have mass, then we'd still probably call that limiting invariant speed the name lightspeed. Because different frequencies of light can get very very close to that speed. So red light and blue light might move at slower speeds, but there would still be a lightspeed that they get closer and closer to. It wouldn't be bluelight speed, or redlight speed (which would both be less than $c$), but it would be lightspeed.
Timaeus
  • 26,055
  • 36
  • 71
The "light cone argument" is equivalent to the light-speed limit, it's a geometric way of demonstrating it. It's not an assumption, you can prove it from tha axioms of special relativity --
Suppose you had a train moving faster than light, and had headlights on it, or a glowing guy sitting on top of it, or whatever. According to a stationary observer (in our frame), the train is moving faster than light, and the speed of light is fixed, so the train is always ahead of the light it emits. But according to an observer sitting on top of the train, the train is stationary, and light still moves at the speed of light, so the light is always in front of him and the train.
It's easy to see why this is a contradiction -- suppose there was some kind of high-tech wall at the end of the train's path. It's programmed to create some sort of catastrophe if it's hit by a train, but only works in complete darkness. According to the stationary observer, the train hits the wall first, before the light -- so nukes go off across the world, his family dies, and he ends up drunk, radioactive and homeless. But according to the guy on the train, the light hits the wall first, so it switches off, and nothing dangerous happens -- he looks around, waves at the stationary guy, who's completely sober.
You can't have contradictions like this in the real world, which is why the only conclusion that can be made is "the faster-than-light train doesn't exist".
(Technically, that's not the only conclusion -- we made the assumption in our analysis that time runs in the same direction for both observers. If you're willing to forgo causality, you can, in fact, have faster-than-light travel. That's why causality and locality are typically treated as synonyms in relativistic physics.)
Bonus -- why we like to talk about light cones: an example
"But isn't the order of things relative anyway due the relativity of simultaneity and all that? How does that not lead to a contradiction?"
It doesn't lead to a contradiction, because disagreements about simultaneity only apply to spatially separated events, which cannot possibly be causally linked -- as long as you don't have observers moving faster than light. The full proof is here: Light cones and causality, here's a quick snapshot:
This is another (but equivalent) proof, by the way, of "no observer's axes can cross the light cone", or "no observer can move faster than light".
-6
It is. A light cone is an abstract thing, it isn't something that actually exists. Claiming something doesn't exist because of something that doesn't exist is definitely a flawed argument. And like Carl Witthoft said above, the light cone is a result of the finite speed of light, not the other way round.
One of which ought to be the wave nature of matter. We can quite literally make matter out of light waves. Then we can diffract electrons, they have a definite wave nature, and waves have a speed. Saying that something made out of waves can't go faster than the wave speed sounds like a good reason to me.
It doesn't make sense because there is no way you can move such that everything else not only moves back to where it was, but never moved at all. Time travel is science fiction. You cannot alter events. What happened happened.
I'm not sure it actually says that, but nevermind.
It is flawed.
Maybe. But while we can rule out matter travelling faster than light, we can't rule out waves travelling faster than light. Note that light waves are transverse waves, then check out seismic waves on Wikipedia. P-waves are longitudinal, whilst S-waves are transverse, and propagate at circa 60% of the P-wave speed. Shock waves are even faster.
John Duffield
  • 11,381
