A Faraday cage within a static electric field leaves an internal electric field equal to $\vec{0}$ (as long as there are enough mobile electrons in the conductor to counteract the external $\vec{E}$).
It could be said as "a Faraday cage is fully opaque to static electric field".
On the other hand, it doesn't act on an external magnetic field.
It could be said as "a Faraday cage is fully transparent to static magnetic field".
Wich equations describe transparency (behaviour) of a Faraday cage submitted to different frequencies electro-magnetic fields?
Ideally I would like to find an absorption spectrum of a Faraday cage from 0 Hz to visible light (1 PHz).
athena
  • 733
According to What is the relationship between Faraday cage mesh size and attenuation of cell phone reception signals? for a Faraday cage with a characteristic mesh size of $l$, then the cut-off frequency $f_c$ corresponds to a wavelength of $2l$, i.e. $f_c = c/2l$. In these circumstances, the wavevector $$k = \frac{2 \pi}{c} \sqrt{f^2-{f_c}^2}$$
Thus when $f<f_c$, the electric field is exponentially attenuated as $\exp(-\alpha x)$, for a cage of thickness $x$, where (if I've done my sums right) $$ \alpha = \frac{\pi}{c} \sqrt{2(f_c^2 - f^2)}$$
If there are no holes at all (i.e. a metal box) then the frequency dependence is explored in Faraday cage in real life
It is shown that $$\frac{E_t}{E_i} \simeq 4 \frac{\eta_{\rm c}}{\eta_0} \exp(-x/\delta) = 0.47 \omega^{-1/2} \exp(-22 \omega^{1/2} x),$$ where $\eta_c$ is the impedance of the conductive material and $\delta$ is the frequency-dependent "skin depth". The transmitted power fraction would be the square of this. The numbers in the above formula are appropriate for aluminium, but the frequency dependence would be the same for any good conductor. Note that at high frequencies attenuation in the medium is important, but even if the box was very thin, that reflection from the surface is extremely important even at quite modest frequencies.
ProfRob
  • 141,325
