Following this link, one can treat dissipation by using a factor $e^{\frac{t \beta}{ m}}$ in addition to the Lagrangian $L_0$ of a system without disspation:
$$ L[q, \dot{q}, t] = e^{\frac{t \beta}{ m}} L_0[q, \dot{q}] \, , \quad \text{where}\quad L_0[q, \dot{q}] = \frac{m}{2}\dot{q}^2 - V[x]\, . $$
The equation of motion associated to $L[q, \dot{q}, t]$ is:
$$ e^{\frac{t \beta }{ m}} \frac{d}{d t} \frac{ \partial L_0}{\partial \dot{q}} - e^{\frac{t \beta}{ m}} \frac{ \partial L_0}{\partial q} = e^{\frac{t \beta}{ m}} \frac{\beta}{m} \frac{ \partial L_0}{\partial \dot{q}} \qquad \Rightarrow \qquad \frac{d}{d t} \frac{ \partial L_0}{\partial \dot{q}} - \frac{ \partial L_0}{\partial q} = \frac{\beta}{2} \dot{q}^2 $$
This equation describes the motion of a particle in a potential under the effect of dissipation forces proportional to its velocity.
Question: If I use Hamiltonian mechanics, this system is described by a single Hamiltonian and the canonical equations of motion. That means that Liouville's theorem holds, and therefore the state density would be constant along the physical trajectories of the system in the phase-space. I can't imagine that this is possible for a system with dissipation, where I would expect the phase-space volume to shrink and the density to grow.
Consider for example a damped harmonic oscillator: The trajectories would be circles with exponentially decreasing radius in the phase space, so the phase-space-volume decreases.
Where is my mistake? I thought the only requirement for Liouville's theorem is that the system is described only by the Hamiltonian. So why does it hold where it clearly should not?
Quillo
  • 5,541
  • 19
  • 46
Quantumwhisp
  • 7,095
This was bumped by Community; there is an accepted answer by Daniel in comments but since comments are fleeting, I will community wiki it:
I haven't done the calculation, but I would assume that with this approach you get different generalised coordinates (e.g. the momentum will be scaled by the exponential factor as well). Liouville's theorem applies to the "new" coordinates, not to the $p,q$ of the original Hamiltonian (those derived from $L_0$ , which are the "familiar" momentum and position).
Reply by OP:
You are right, this explains it. Indeed, the momenta will be rescaled with the exponential factor. This would also mean, that "rescaling" to the "old" momentum and location coordinates $(p, q)$ is not a canonical transformation.
CR Drost
  • 39,588
In my opinion, we should define the Lagrangian only when the force is conservative. Eventhough the force is not conservative, we can write down the Lagrangian which is mathmatically correct. However, the Lagrangian and the Hamiltonian do not contain correct nature inside it. Only mathmatically, those work. So, the divergence is still zero, but this does not means that the density in the phase is constant.
