I was thinking about the big bang, and I remembered that neutrinos not only travel at the speed of light, but they were also created in massive quantities very early in the universe (Hadron epoch).
Since the universe around that time was about the size of our solar system now, and neutrinos don't interact with matter very much, wouldn't those neutrinos be the 'edge' of the universe? I'll call this edge a 'neutrino shell'.
If I remember correctly, the Shell Theorem should apply here - except for one thing: if the speed of gravity is the speed of light, wouldn't matter feel some slight more gravitational power closer to the 'side' of the universe it started in?
That's because the other 'side' of the universe (assuming a sphere) is moving away from us faster than the speed of light - implying the force of gravity exerted by those neutrinos at some point disappeared.
And this would also mean that at some point the entirety of this 'neutrino shell' of the universe would be so far away from every piece of 'physical matter' in the universe, moving at speeds faster than the speed of light, that it would stop exerting gravity upon all matter?
And wouldn't that mean that after that time, the universe should stop expanding and start deflating (because galaxies inside the shell now have no 'external' gravity force exerted by the neutrino shell)?
I don't know if this makes sense or am I missing a fundamental piece of physics here?
The Big Bang didn't happen at a point then expand outwards.
The model we use to describe the universe, the FLRW metric, is based on the assumption that the universe is homogeneous i.e. it is everywhere the same. That means the neutrino density is constant everywhere and has been constant for as long as the neutrinos have existed. There is no shell of neutrinos at the edge of the universe.
Neutrinos are relativistic and as a result their energy density falls as $a^{-4}$, where $a$ is the expansion scale factor. By comparison the energy density of non-relativistic matter falls as $a^{-3}$ so the ratio of neutrino energy density to normal matter energy density falls as $\tfrac{1}{a}$. This means that for very small $a$, i.e. close to the Big Bang, the gravitational influence of neutrinos dominates over normal matter. However for large $a$ (small $\tfrac{1}{a}$) the gravitational influence of normal matter dominates over neutrinos.
I'm not sure when the switchover occurred, but neutrinos are currently gravitationally insignificant. Relativistic matter, including photons as well as neutrinos, ceased to dominate around 30,000 years after the Big Bang. Just as well really, as if neutrinos were still gravitationally significant they would have stopped matter clumping to form stars then galaxies and we wouldn't here to debate the point.
John Rennie
  • 367,598
