31
What is a state in physics? While reading physics, I have heard many a times a "___" system is in "____" state but the definition of a state was never provided (and googling brings me totally unrelated topic of solid state physics), but was loosely told that it has every information of the system you desire to know. On reading further, I have found people talking of Thermodynamic state, Lagrangian, Hamiltonian, wave-function etc etc which I think are different from one another. So in general I want to know what do we mean by state in physics and is there a unique way to describe it?
5 Answers5
32
Our physics prof once put it informally that way:
A state is a set of variables describing a system which does not include anything about its history.
The set of variables (position, velocity vector) describes the state of a point mass in classical mechanics, while the path how the point mass got from point $A$ to point $B$ is not a state.
Jens
  • 3,729
30
The definition of a state of a system, in physics, strongly depends on the area of physics one is dealing with and it comes as one of the initial definitions once such underlying theory has to be set up. In particular one has:
  1. classical mechanics: a state of a system is a point $m\in TQ$ (or equivalently $T^*Q)$ in the tangent bundle of the configuration space (or the phase space, respectively). Such state is identified on a local chart with a set of coordinates $(q_i, \dot{q}_j)\in\mathbb{R}^N$ representing positions and velocities of all the particles at a given time $t$. Such description is equivalent to require the uniqueness of the solution of the Newton's equations once initial conditions are specified.
  2. thermodynamics: a state is a set of extensive variables $(X_1,X_2,\ldots,X_N)$ that uniquely specify the value of the entropy function as $S(X_1,X_2,\ldots,X_N)\in\mathbb{R}$. Such variables represent the macroscopic extensive parameters (as volume, number of particles, total energy and so on and so forth) from which one can derive the corresponding associated intensive variables taking derivatives of the entropy as, for instance, $p=T(\partial S/\partial V)$ and similars.
  3. quantum mechanics: a state is any element $|\psi\rangle\in\mathcal{H}$ of a Hilbert space together with a collection of self-adjoint operators $(A_1,\ldots,A_n, H)$. Special role is played by the Hamiltonian $H$, whose action mirrors classical mechanics giving the evolution in time of the state $|\psi(t)\rangle$. A collection of states (i. e. an ensamble) is instead described by a density matrix $\rho$ such that the expectation value of any operator on the ensamble can be defined as $\langle O \rangle = \textrm{tr}(\rho O)$.
  4. field theories: very subtle as the definition of a state strongly depends on the theory at hand (quantum gravity, loop quantum gravity, string theory, QFT all have slightly different definitions of states).
EDIT: as per the suggestions in the comments below, more complex states and descriptions may and do arise, therefore the above is supposed to only be taken as general walkthrough.
gented
  • 6,058
12
Informally speaking, a complete description of a physical system is referred to as its state. Completeness of the state of a system means that it provides all the possible information about the system, i.e. everything that can be possibly known about the system has to be contained in the specification of its state.
Every physical theory is ultimately based on the following three fundamental postulates:
  • The postulate which defines the way we describe a state of a system.
  • The postulate which specify what kind of information about observables, i.e. measurable properties of the system, is contained in the description of its state.
  • And the postulate which provides us with a law that governs the time evolution of the system and allows us to predict its future state given the current one.
And in view of these fundamental postulates the meaning of completeness of the description provided by the state of a system is that all possible information about observables should be contained in the specification of the state and it should also be possible to use it to obtain all possible information about observables at any time in the future.
To make the definition of a state more formal and less vague we have to at least distinguish between classical and quantum theories because concrete manifestations of the above mentioned postulates for these two families of physical theories differ significantly. For instance, the meaning of the "all possible information about observables" phrase in quantum theories is quite unconventional from the classical point of view. And the rigorous definitions сan be given only for a particular physical theory since different mathematical objects are used to represent the state of a system in different theories as discussed in details in the answer given by Gennaro Tedesco.
Wildcat
  • 1,830
State in physics is a usefully ambiguous term, which is used in different ways in different fields; it's probably best understood in opposition to dynamics: state is static, and says nothing about motion; whereas dynamics tells you how one state evolves into another.
For example, in classical picture a state would be both the position and the momentum of a particle; knowing all the states of all the particles in the universe gives a snap-shot of the universe, or the state of the universe; but knowing all this does not tell you the state at some future moment - for this one also needs to know the dynamics - that is, the equations of motion; or simply how one state changes into another.
Another example, would be QM; there a state encodes the quantum system at hand, and (in the Schrodinger picture), are time-independent; the dynamics would then be given by Schrodingers equation which says how the state - the wave or potential - evolves.
(There is here, though the crucially complicating factor of observables, and acts of measurement).
However, it's also worth noting that there is another picture, the Heisenberg picture, where states do not evolve but observables do - this picture is more useful for the move into relativistic QM and/or QFT.
Mozibur Ullah
  • 14,713
Roughly, you describe state in physics as a series of particular values assigned to the different magnitudes that you can measure of the system, i.e. a value for the energy, pressure, temperature, ... or any magnitude that you're interested in.
So the state is a way of describing which properties has the system that you're going to study.
S -
  • 1,583
