My Professor says that all members of the restricted Lorentz group $SO^+(1,3)$ may be written as $e^\Gamma$, where $$ \Gamma^{\mu}{}_{\nu}=\Lambda^{\mu \rho} \eta_{\rho \nu}.$$ Here $\Lambda$ is an antisymmetric Matrix, and $\eta$ is the standard Minkowski metric [$diag(1,-1,-1,-1)$]. I want to prove a weaker statement. That all matrices of the said form belong to $SO^+(1,3)$. I have been able to show that they belong to $SO(1,3)$. However, the orthochronous bit is troubling me. Any help is appreciated.
Progress so far: $$(\Lambda \eta)^T=-\eta \Lambda$$ $$\implies (e^{\Lambda \eta})^T=e^{-\eta \Lambda}$$ $$\eta e^{-\eta \Lambda} \eta=e^{-\Lambda \eta}$$
$$\eta e^{-\eta \Lambda} \eta e^{\Lambda \eta}=I$$ $$e^{-\eta \Lambda} \eta e^{\Lambda \eta}=\eta$$ $$\implies (e^{\Lambda \eta})^T\eta e^{\Lambda \eta}=\eta.$$
Hence $e^{\Gamma} \in O(1,3)$. Further, Suppose $\Lambda$ is written as $$ \begin{bmatrix} 0&\vec{\lambda}\\ -\vec{\lambda}&R\\ \end{bmatrix} $$ Where $R$ itself is antisymmetric. Block Multiplication on the right by $\eta$, gives $\Lambda \eta$ to be, $$ \begin{bmatrix} 0&-\vec{\lambda}\\ -\vec{\lambda}&-R\\ \end{bmatrix}. $$ Clearly Trace of $\Lambda \eta$ is 0. Hence $Det(\Lambda \eta)=1$. Therefore $e^{\Gamma} \in SO(1,3)$.
Comments to the question (v2):
  1. That the exponential map $$\exp: o(1,d) ~\to~ O(1,d)$$ has image $$\exp(o(1,d))~\subseteq~ SO^+(1,d)$$ inside the restriced Lorentz group $$ SO^+(1,d)~:=~\{ \Lambda \in SO(1,d) | \Lambda^0{}_0>0 \} $$ follows from the facts that the image of a connected set under a continuous map must again be connected, cf. above comment by Emilio Pisanty. (One more hint: No Lorentz matrix $\Lambda$ can have zero determinant $\det(\Lambda)=0$ or zero 00-entry $\Lambda^0{}_0=0$, cf. e.g. this Phys.SE post.)
  2. The non-trivial fact that the exponential map $$\exp: o(1,d) ~\to~ SO^+(1,d)$$ is surjective is discussed in this Phys.SE post.
