If one is constrained to the $xt$ plane, one can define the intersection with that plane of the null hypersurfaces originating at some point $P$ as
$$ g_{tt} \frac{d P^t}{d \lambda}\frac{d P^t}{d \lambda} + g_{xx}\frac{d P^x}{d \lambda}\frac{d P^x}{d \lambda} = 0,\tag{1}$$
$$ \sqrt{ \frac{g_{xx}}{-g_{tt}}} \frac{d P^x}{d \lambda} = \frac{d P^t}{d \lambda}. \tag{2}$$
It is not clear that a curve satisfying this equation will also satisfy the Geodesic equation:
$$ \frac{d^2 P^{\alpha}}{d \lambda^2} = - \Gamma^{\alpha}_{\beta \gamma} \frac{d P^{\beta}}{d \lambda} \frac{d P^{\gamma}}{d \lambda}.\tag{3}$$
What would be a reasonable approach to show that the first equation is also a geodesic?
Comments to the question (v3):
  1. In 3+1D, the 1D-intersection of a null-hypersurface with the constraints $y=0=z$ does not need to locally be a geodesic, as simple counterexamples show.
  2. The analogous 1+1D question is more interesting: In 1+1D, the eq. (1) is locally always a non-affine parametrized geodesic. It does not have to satisfy the affinely parametrized geodesic eq. (3). For a proof, see my Phys.SE answer here.
