According to many sources (including Wikipedia, Stephani&Kluge, D.J. Acheson) a steady state ist:
In systems theory, a system in a steady state has numerous properties that are unchanging in time. This means that for those properties $p$ of the system, the partial derivative with respect to time is zero:
$$ \frac{\partial p}{\partial t} = 0 $$
But why is it defined like that? Why not ${d \over dt} p=0$ ? If only $ \frac{\partial p}{\partial t} = 0 $ then there will still be change in time if $p=p(\vec r(t))$ !
Since people seem to disagree that this is even a legitimate question here is a motivation for that, Wikipedia about total and partial derivative:
The total derivative of a function is different from its corresponding partial derivative ($\partial$). Calculation of the total derivative of f with respect to t does not assume that the other arguments are constant while t varies; instead, it allows the other arguments to depend on t.
So why can we assume the other variables are constant? If we are using $ \frac{\partial p}{\partial t} = 0 $ to determine if a steady state is present, why should we be able to assume no indirect dependence on time exists?
My try to explain it, if it is nonsense, of course an explanation why would be great, but just a good answer to my question would be too:
Reasons why ${\partial p \over \partial t} =0$ might make more sense than the total derivative to equal zero.
1. ${d p \over dt} =0 $ on it's own already indicates a conservation of the flux $j$ and density $\rho$ associated with $p$ by Reynolds theorem: $${d \over dt} p={d \over dt}\int_V \rho dV= \int_V \frac{\partial \rho}{\partial t} dV+ \int_{\partial V} \underbrace{\rho \vec v}_{= j} \cdot \vec n dA$$
since ${d p\over dt} =0$ normally holds independent of V if we use Gauss theorem $$\Rightarrow \frac{\partial \rho}{\partial t}+\nabla j=0$$
We see the total derivative being zero gives us a continuity equation.
2.
${ d p \over dt} =0 $ implies if we write it out $${dp \over dt } = { \partial p \over \partial t} + ( v \nabla ) p=0$$ i.e. $${ \partial p \over \partial t} =- ( v \nabla ) p$$ So by the definition of the partial derivative: if we hold all other variables and only look at the change in $t$, we see, this derivative does not vanish and we even have a time dependend $p$.
