I know that mid wave IR, long wave IR, and far IR are all infrared light that we feel as heat. Often, even when it is cold and windy, if I face the sun in a sunny spot it feels like it is 80 degrees F because of the IR light from the sun.
I know that all heat is at least partly IR light, even our own body heat. But what wavelengths of IR light are hotter? Is it mid wave IR because of its high frequency or is it far IR because of its long wavelength?
Caters
  • 279
There seems to be some confusion here - the perception of "heat" from an IR lamp relates to the amount of energy absorbed by the body. This depends on the reflectivity of the skin at that particular wavelength; also, you would have to normalize this in some way.
Now we know from Planck's Law that there is a distribution of wavelengths from a black body: the peak emission goes to shorter wavelengths as the body gets hotter. Importantly though, at any given wavelength the emission density is great eras the temperature of the black body goes up.
It is not directly possible to answer your question without somehow deciding how to normalize the intensity: if we decrease the wavelength of the IR by making the emitter hotter, we will always experience greater heating.
I recommend that you look for reflectivity curves for skin: if the skin absorbs the radiation it will feel warm. Everything else is a matter of how you normalize.
Floris
  • 119,981
