I know this sounds like (and probably is) a stupid question, but I can't figure it out.
As far as I know, the crescent shape of the moon is when the moon is on the sunny side of the Earth, but that wouldn't explain how it can be seen from the night.
Horrible, not-to-scale and probably completely wrong diagram of what I think here:
diagram
How is it that we can see clear to the other side of the Earth?
Zach Saucier
  • 1,191
imyxh
  • 141
Your diagram is not quite to scale, and the errors are important. Notice that only the hemisphere of the moon which points toward the sun is illuminated, rather than what your drawing shows. This has the following implications.
1) When the moon is new, it rises and sets at the same time as the sun, and is not (mostly) visible at night. The extreme example of this occurs when there is a solar eclipse.
2) When the moon is full, it rises at sunset and sets at sunrise, and is visible during the entire night.
3) When the moon is at half-illumination, it is only visible for half the night.
So the answer to your title question is "We can't."
The dark portion of the moon is not actually dark, since it is illuminated by light reflected by the earth. When the sky is dark, you can see the dimly-illuminated portion fairly clearly, but during daylight hours the sky is brighter than the dark portion of the moon, and that portion is invisible against the sky. That's why you can't see the moon just before and after a solar eclipse.
Here's a slightly more accurate diagram:
Diagram of crescent moon visible from the night side of Earth
It's still not quite to scale — the Moon is actually a lot further away from the Earth than shown here — but it should suffice to demonstrate that the moon can indeed be seen from the night side of the Earth even when it's nearly between the Earth and the Sun. Note how, in the orientation shown in the diagram, the side of the Moon visible to Earth is almost completely dark, with only a thin crescent lit by the Sun.
The diagram also illustrates some notable properties of the Sun-Earth-Moon geometry:
  • The crescent Moon is only visible (at night) shortly after sunset or before sunrise. Indeed, for the Moon to be visible at midnight, it must be at least (approximately) half full. There's some fuzziness here due to the fact that the Earth's axis of rotation doesn't perfectly match the axis of the Moon's orbit, but even so, you can never see a thin crescent Moon at midnight — unless you're close enough to the Earth's poles that you can see the Moon over the pole.
  • The lit side of the Moon's disk at night always faces (more or less) downwards, towards the Sun. At the equator, it faces (almost, again due to axial tilt) straight down; the further north or south you go, the more the Moon's crescent is tilted, but even so, it never faces upwards while the Sun is below the horizon.
Of course, another reason why we can see the crescent Moon is that the Moon is actually quite visible even during the day:
Daytime Moon and Clouds by Alana Sise
Daytime Moon and Clouds by Alana Sise @ Flickr, used under the CC-By 2.0 license.
-2
How can we see the moon while it's between the Earth and the Sun?
This phenomenon is called "Solar Eclipse". You do not really see the moon, you simply do not see the sun because of the moon which block the sunlight.
