-1
Using basic logic.... We know speed and velocity is relative. My point is if we take our speed with respect to a photon moving in opposite direction we are practically moving at speed greater than that of light...... Is my argument correct?
David Z
  • 77,804
No your argument is not correct. Firstly, velocities do not add linearly like 3-vectors in Euclidean space: the relativistic sum of two velocities always has a speed of less than $c$ if both the velocities' magnitudes are less than $c$ (no matter what their direction).
Secondly, photons have no rest frame: that's a basic property of things that have zero rest mass. A's speed relative to B is the speed of A measured from the frame wherein B is at rest. So let $B$ be your photon and $A$ be some other observer. But in this case, B has no rest frame. So we cannot give a meaningful answer to what $A$'s velocity relative to $B$ is. If $B$ were something other than a zero rest mass object and were moving relative to us at $c-\epsilon$ where $\epsilon$ were as small as you like, then we wouldn't run into this problem and you could calculate the relative velocity. But, as stated above, this relativistic sum cannot have a magnitude greater than $c$.
So if your question were, do we move at velocities near $c$ relative to, say, an electron accelerated to near the speed of light relative to us, then the answer would be "yes we would move at that same near to $c$ speed relative to the electron".
Selene Routley
  • 90,184
  • 198
  • 428
