-1
It is known that in simple harmonic motion, the total energy of the system is proportional the square of the amplitude, but how can I prove that for a simple pendulum where amplitude is the arc length of the part of the circle? Much obliged for any help.
Suppose the maximum angle of the pendulum to the vertical direction is $\theta$, where the pendulum has a zero-velocity. According to the conservation of mechanical energy, the total energy of the system, $E$, should be:
$$E=mgl(1-\cos\theta )$$
If $\theta$ is small enough, we can expand $\cos\theta$ up to the second order:
$$\cos(\theta)\approx 1-\frac{\theta^2}{2}$$
Plug this into the energy formula, we can get:
$$E=mgl(1-\cos(\theta))\approx mgl\left[1-\left(1-\frac{\theta^{2}}{2}\right)\right]=\frac{mgl\theta^2}{2}$$
The total energy of the simple pendulum system is proportional to $\theta^2$. It should be noted that this relation just holds when $\theta$ is very small, only based on which $1-\frac{\theta^2}{2}$ can be a good approximation of $\cos\theta\; .$
bitsoal
  • 126
