I've recently understood de Broglie's hypothesis, and I understand that a necessity for electrons to show diffraction is that the size of the aperture they pass through must be of the order of their de Broglie wavelength. So exactly what would happen if (if) I were to walk through a door of a size of the order of my de Broglie wavelength? If a number of people of the same order of masses did so?
Asked
Active
Viewed 253 times
-1
Your de Broglie's wavelength is (assuming your weight is around 70 kg and you are moving 1 m/s) $\lambda = h/mv = 6.6\times10^{-34}/70 \approx 10^{-35} $ which is less then the Plank length - the least sensible distance. And this is much less than the diameter of protons/neutrons so even decomposed on elementary particles you wouldn't fit into such a door.
Ilya
- 892
