15
My question has 2 parts:
  1. I just followed the derivation of Navier Stokes (for Control Volume CFD analysis) and was able to understand most parts. However, the book I use (by Versteeg) does not derive it in its entirety. He pulls a lot of results directly from Schlichtling and continues his analysis. I want to understand the derivation in its full form. Is there any resource other than Schlichtling (My library doesn't have it) for deriving the NV equations in their full form? I would prefer an online (free) PDF or similar. (I'm not sure my library would have many books on this including the ones discussed here)
  2. After the derivation, most books follow it up with :
$$\underbrace{\frac{\partial (\rho\phi) }{\partial t}}_{\text{Rate of increase of }\phi} +\underbrace{\text{div}(\rho\phi \vec u)}_{\text{Convective Term}} = \underbrace{\text{div}(\Gamma \text{ grad}(\phi))}_{\text{Diffusive Term}} + \underbrace{S_\phi}_{\text{Source Term}}$$ where $\phi$ is property per unit mass, $\vec u$ is velocity vector and $\Gamma$ is diffusive term (Like viscosity or thermal conductivity).
What I can't understand is the use of the terms "convective" and "diffusive"? What do they mean? What is the physical interpretation of these terms?
Their dictionary meanings seem to exacerbate the situation:
(convection) the transfer of heat through a fluid (liquid or gas) caused by molecular motion.
(diffusion) The spreading of something more widely or the intermingling of substances by the natural movement of their particles
I don't know a good answer to your first question (I'd be interested in a good text for that myself), but I can answer the second.
It's easier to explain if we temporarily imagine $\phi$ represents the concentration of some dye made up of little particles suspended in the fluid. The convective term (aka advective term) is transport of $\phi$ due to the fact that the fluid is moving: a single "particle" of $\phi$ will tend move around according to the velocity of the fluid around it. The diffusive term, on the other hand, represents the fact that the dye tends to spread out, regardless of the motion of the fluid, because each particle is undergoing Brownian motion. So if you were moving along at the same velocity as the fluid you would see a small spot of dye tend to become more and more blurred over time.
For quantities like energy and momentum the diffusion happens for a slightly different reason (transfer of the quantity between fluid molecules when they collide) but the principle is the same. The property is transported along with the fluid's bulk velocity (convective term) but also tends to spread out and become blurred of its own accord (diffusive term).
N. Virgo
  • 35,274
For the first part of the question, I would recommend Analytical fluid dynamics Book by George Emanuel. The book is the only book that gave derivation of N-S equation in a way that I liked. Otherwise, books by Kundu-Cohen, GK Batchelor, or Landau-Lifshitz are also good resources.
For the second part, I would like to add one more point in Nathaniel's answer. The diffusion N-S equation is represented by shear viscosity, as the fundamental mechanism of shear viscosity is the diffusion of momentum among different fluid layers. So, terms in the multiplication of viscosity are diffusion terms.
Note: The diffusion of momentum in dilute gases is caused by the diffusion of particles alone. In dense gases and liquids, the intermolecular attraction force also contributes to momentum diffusion. So, especially in gases, the shear viscosity is also directly related to the diffusion of mass. (See kinetic theory of gases for more detail)
"The terms on the left hand side of the momentum equations are called the convection terms of the equations. Convection is a physical process that occurs in a flow of gas in which some property is transported by the ordered motion of the flow. The terms on the right hand side of the momentum equations that are multiplied by the inverse Reynolds number are called the diffusion terms. Diffusion is a physical process that occurs in a flow of gas in which some property is transported by the random motion of the molecules of the gas. "
http://www.grc.nasa.gov/WWW/k-12/airplane/nseqs.html
