Beside the obvious answer black hole, is there anything else? Could a nearby supernova blow it away/apart? Or any sort of (theoretically intense enough) field? I guess an electric field is out of the question no matter how strong.
Sorry if this a lazy/amateurish question, but I'd probably have to study degenerate matter a lot before I can answer this myself comprehensively. I suppose the question asking What is the binding energy of a neutron star? is related, but I don't know how to interpret it myself in layman's terms.
Do you mean anything in the real universe or just theoretically? If the latter, then I can think of a few phenomena:
  • Heat: Just heat it up until the thermal velocity at the surface is greater than the escape volcity. Then neutrons will just fly off and it will evaporate (sublimate?).
  • Spin: Wind it up until the tangential velocity at the equator reaches escape velocity. This might be self-limiting as the spun-off mass takes away angular momentum. You'd have to keep winding it.
  • Tides: Drive it past a particularly dense Black Hole and let the tidal forces pull it apart.
In all these cases, I'm not sure how the nuclear Strong Force might modify the calculations (it might not be only gravity holding the neutrons down).
To expand on those answers, I did a few BoE calculations assuming only gravity, to see what kind of values we'd need for each of these cases. We start with a typical neutron star:
mass, $M = 1.4M_\odot$ (so, $2.8 \times 10^{30}kg$)
density, $\rho = 5 \times 10^{17}kg/m^3$. This gives:
radius, $r = \sqrt[3]{{3M}/{4\pi\rho}} = 11km$.
escape velocity, $v_e = \sqrt{{2GM}/r} = 1.8 \times 10^8 ms^{-1}$ (or $0.6c$)
  • Heat: $v= \sqrt {{3kT}\over m}$, so $T = {{mv^2}\over{3k}}$, where $m$ is the neutron mass and $k$ is Boltzmann's constant. This comes out at around $10^{12}K$, which is rather hot (interestingly, it's within a factor of 10 of the core temperature in a supernova, where neutron stars are made).
  • Spin: $v_e=r\omega$ and $w=2\pi f$ so $f = {v_e \over {2\pi r}}$. Plugging in the numbers gives a rotational frequency of 2.6 kHz or 150,000 rpm. Quite a rate for a thing the size of a mountain.
  • Tides: The equation for the Roche Limit is $d = 1.26 R_M (M_M / M_m)$. If we find a black hole of $3M_{\odot}$ and a radius of 9km, we just have to steer our neutron star to within 24Km and it'll just fall apart.
Oscar Bravo
  • 4,523
I'm going to add another way to break up a neutron star. Shoot antimatter at it.
The difficulty with breaking up a neutron stars is that, once they undergo the compression to become Neutron stars, their gravitation tends to keep them there. The minimum size for a Neutron star to form is about 1.2-1.5 solar masses, but once it's shrunk down, the mass it needs to maintain the Neutron compression is a lot less than that, perhaps around 0.1 solar masses. See here for much more detailed answer on minimum Neutron star size.
The outside of a Neutron star is highly compact heavy ions and flowing electrons.
http://msnlv.com/internal-structure-of-a-neutron-star.jpg
Source
So, if we shoot it with positrons, the positron hits an Electron and evaporates into gamma rays and you're left with a positively charged Neutron star, shoot it enough and the positive charges will gradually build a force that resists the gravity (granted, it also becomes more resistant to continued firing of Positrons), but if you manage to shoot it enough times and you might just be able to cause the Neutron star to expand and overcome the gravitational force that keeps it in it's Neutron state.
Now, maybe you'd need to hit it with anti protons / anti neutrons to reduce more mass as positrons alone might not get the job done, but I like the positron idea cause it preserves the baryonic matter and if you get the Neutron star to expand and when that happens, the Neutrons begin to decay into protons, so you're left with basically a hydrogen star. Granted one with an unnaturally high positive charge.
userLTK
  • 5,778
The neutron star is still "regular enough mater" for that it would react to anything a normal object would react.
To me the point is more "since its center is not far to collapsing to blackhole, is it possible to shake (or breakup) a neutron star without making it collapse".
The only likely mechanism by which a neutron star can break up is through a collision with another neutron star, in particular in binary neutron star mergers.
