Suppose a baseball is traveling through a vaccum towards another object extremely fast. If it's travelling fast enough then shouldn't its kinetic energy give it enough mass that the observer thinks it should collapse into a black hole and evaporate as Hawking radiation? How can this be reconciled with the perspective of a second object at rest with the baseball, which would have no reason to see a black hole?
Asked
Active
Viewed 84 times
You start from a common and stubborn misconception: that objects acquire mass at high, relativistic speeds.
In reality it is the object's momentum $p$ that is relativistic:
$$p=\frac{mv}{\sqrt{1-\frac{v^2}{c^2}}},$$
where $m$ is mass, $v$ is velocity and $c$ is the speed of light.
See relativistic mass.
So your relativistic object could never acquire the mass needed to form a black hole.
Gert
- 35,561
