Let's say we've built a machine, that prints a sequence of all natural numbers from 0 to $\infty$. We "could" do this in a Universe with an infinite amount time (if we also make many other assumptions I don't want deal right now with). What if we would like to do the same experiment, but this time we print the real numbers? The two infinities (the amount of all natural and real numbers) are very different in nature. One is bigger than the other. If one says the Universe will last forever, does by "forever" he mean the amount of time that can be counted by the first machine, which prints a number, for example, every second? Or by "forever" he means some continuous line where time is not something you can quantize? Or is the "physical infinity" something very different from mathematical?
I probably do not understand the concept of time whatsoever, because I think it might have something to do with "events occurring at a specific rate relatively to some other events occurring at some other rate". If there are no events (for example the Universe "dies", "cracks" or whatever), there is no time then and no sense of measuring it (either by counting its "seconds" or stating it's a continuum).
But I would really like to know what does a physicist mean, when he uses the word "infinity" when he's talking about time related to the future history of our Universe.
kuonirat
  • 115
Well, since your machine prints a finite amount of numbers in a finite time, it always print only a countably many numbers.
You can just divide the time from now to infinity in equally sized chunks of "1" to get a countably infinite set. During each of those chunks you print some amount of numbers, which in total gives you another countably infinite set. So that process "quantises" time.
When physicists say "infinite" they mean more often than not that the quantity is bigger than anything else we compare it to. In case of the universe, no matter what $t$ you pick, the universe still exists.
In calculations, we often write $\lim_{T\to\infty}$, where $T$ is the quantity of interest. That makes it very easy to make manipulations without worrying too much about how big $T$ actually is.
Daniel
  • 745
No. You can't ever build such a machine. You machine has a finite number of parts that can be arranged a finite number of ways, so there is a finite number of numbers it could print out.
That doesn't even make sense. Again, you can only print numbers that have a finite description, the describable numbers. And mathematicians would describe that as a mere small (and boring) subset of the real numbers.
The natural numbers and the describable numbers aren't that different, one is an encoding of the other. The alleged undescribable numbers are different.
They are pretend.
You can't say a pretend thing is larger than something else. And even mathematicians don't say one is larger. They instead talk about an abstract partial order (a reflexive, transitive, antisymmetric relation) that bears similarities to size comparisons and then they use isomorphic (correspondingly similar) language.
And if you tried to claim one was actually bigger, what do you do about the downward Lowenheim-Skolem theorem? Question beg it by assuming larger things in your language or logic? And what's the point if one collection is full of pseudoscience (the undescribable numbers are by definition never going to be seen).
We mean that for any region of spacetime and any level of accuracy there are models that agree with observations in that spacetime up to that accuracy and that for any describable number D there regions of spacetime such that the corresponding parts of the model have time like curves that extend from that region to have a proper time that exceeds D.
And we could have used just the naturals or just the square numbers or any unbounded sequence. Or you could just say the proper times that curves extend are not bounded.
In science you never have to bring up fictional alleged undescribable numbers since be definition they don't actually show up in either a theoretical prediction or in an experimental observations.
They can be safely confined to storytelling about the mathematical models. Which is fine, if having them makes it easier to talk about the models, then have then if you want. But they aren't where the important things happen. The can't be, they never will be, and they were merely alleged anyway.
When a physicist says continuous and a mathematician says continuous they aren't talking about the same thing. A physicist is contrasting models, and so is distinguishing models with discontinuities from models without such discontinuities. The physicist isn't worried about which numbers exist beyond the ones that are needed to make the predictions.
Yes. The physical one is agnostic at best about alleged numbers that are never actually seen.
Fundamentally you should learn what an event is. That is the proper unified generalization of a moment and a location. Then you can learn about durations, which is a generalized length of curves made up of events.
No, its just a length. Just like a space has a length of a curve, so a 4d spacetime has a generalize length associated to a curve in 4d and that is duration. And in general they don't have a super close relationship to any naive notion of time or duration in particular that everything is comparable. A length of a curve is a length of a curve and it is pretty unrelated to other curves which have their own lengths.
If there are no events there are no questions to ask and no universe. Either do physics or do not, there is no try.
Not bounded.
is it really the case you can't get for example $\sqrt{2}$ in a theoretical prediction or in an experimental observation as an actual value? What about rational numbers?
You can describe the natural numbers. You can describe the integers. You can describe he rationals. You can describe the algebraic numbers (which includes $\sqrt 2$ and every other zero of a polynomial with integer coefficient). And that's all still countable. But you can describe more. You can describe $\pi$ you can describe $e$ you can describe any computable number (one with a finite program for a fixed Turing Machine that takes an arbitrary natural number n as input and then prints the nth digit of the number). You can even describe some uncomputable numbers such as Chaitin's constant, the number between zero and one whose nth binary digit is zero or one depending on whether the nth program for a fixed Turing Machine ever halts or runs forever.
The describable numbers contain any specific fixed number that could ever be described with a finite description. And it can get a bit fussy to nail that down exactly and precisely. But if the number can be described clearly enough that there is an obvious and objective answer to what its digits are, then that roughly means it is describable.
What it does not include would be numbers with random digits. And since you can list the descriptions, a mathematician will say that "most" real numbers are indescribable. But they are also pointless for science. They don't come up in specific predictions, they don't come up in specific measurements or in specific observations. They can't be specified in a procedure so that a specific protocol can be repeated.
What a mathematician calls the real numbers is supposed to be vastly bigger and more more complicated than what can be described. But obviously they can't exhibit a single example concretely, they could try to assert that there is a number between zero and one whose binary digits encodes a belonging relationship on the natural numbers that satisfies the ZFC axioms. But firstly we don't know if such a number exists. Secondly they can't actually prove it exists. And thirdly, even if such a number exists there are many such numbers and they still haven't described a single one of them.
The indescribable numbers are allegedly vast but we've never seen a single one and we never will. And we don't actually need them. If pretending they are there makes things easier or more convenient, maybe they are harmless, like a ghost story. But if you start to worry about them like they matter, then this is a sign of a deep problem or that you have waded into pure nonsense and you should go back and learn from your mistake. Just as if you started to worry about specific ghosts as if that was affecting your experiments. The fiction should have been harmless and convenient or you shouldn't have done it at all.
If your number has digits and you can describe them all and a describable specific order in some finite description then its a perfectly fine number. And there aren't oodles of those numbers.
We don't need numbers to act as Oracles, secretly knowing and pre-encoding mystically unknowable outcomes by an unknowable non procedure.
Timaeus
  • 26,055
  • 36
  • 71
The only honest answer is we don't really know, and may not know ever. If you think about it by trying to consider properties of $\mathbb{R}$, I'd vouch you are actually taking the maths "too seriously". There is no empirical evidence, and cannot be, that space time really is $\mathbb{R}$ (or well, some expanded/warped version i.e. an $\mathbb{R}$-manifold), something whose mathematical properties will also depend on things like what axioms of set theory (or some other suitable mathematical framework theory but ZFC set theory is the one usually used) you take as valid and what not. $\mathbb{R}$ is used because it's a convenient structure. From an empirical point of view, all measurements are finite in number and limited of precision, so they could be described in a sense as a strict finite subset of $\mathbb{Z}$. But writing down physics math would be hideously difficult and unintuitive in $\mathbb{Z}$. (This is why I just said there "cannot be any empirical evidence that space-time is $\mathbb{R}$" because that would require examining it to infinite resolution, an impossibility.) So we choose $\mathbb{R}$ as a convenience tool for modeling. To then extract "predictions" about the universe based on deep-analyzing $\mathbb{R}$ is like trying to analyze this post by scrutinizing the precise shapes of the letters of the font it is displayed in, and then claiming that tells you something meaningful or relevant about the content of that post. In particular, regarding your argumentation about "printing the real numbers", math says that any list of the real numbers must have ordinal type greater than $\omega$, in fact vastly greater. But here's the cinch -- just what ordinal type will depend on what you assume about your set theory. It is firm that at the least we can have $\mathrm{ordinal\ type}(\mathrm{list}\ \mathbb{R}) = \omega_1$, but it could be much larger. In fact you can arbitrarily jig your set theory with great freedom to choose what it is. This freedom shows you then it's like scrutinizing the deep details of our modeling tools.
That said, we can falsify that the universe is $\mathbb{R}$. Show that there's an absolute minimum increment of space and time, and then it's done. In lieu of that, we won't know. And I'd say it's not necessarily reasonable to consider it "verified to high confidence" like other theories even if we measure extraordinarily fine, because $\mathbb{R}$ as a choice is still a modeling choice to undergird what will always be finite precision anyway.
Pragmatically, you cannot build your infinite machine. Entropy will destroy it or render it privated of energy to keep going, before it can run 'infinitely long'. Nothing lasts forever in the universe. Thus any clock or ticker or whatever we can ever build will only measure as much time as entropy takes to kill it off.
Mathematically though, the longest "ruler" you can construct in $\mathbb{R}$ with regularly-spaced ticks (either a spatial ruler, or a clock ticking at regular intervals) will have ticks with ordinal type $\omega$, that is, the "type of infinity" is that of the natural numbers. But as just discussed, this says nothing about the real universe. Thus a "listing machine" in a hypothetical $\mathbb{R}$-universe will not list all the elements of $\mathbb{R}$. But if it's something bigger than $\mathbb{R}$, that may be possible at some (non-Archimedean, trans-finite) time in the future (but it will have to be a LOT bigger, I believe.).
