This question is related to this fascinating post and this post and this post, but more limited in scope in discussing the practical definition canonical transformations.
Canonical transformation from one of four generating functions
Traditionally, canonical transformations are generated by derivatives of a generating function. For example, for $F_2(q, P)$, we have \begin{align} p &= \frac{ \partial F_2 } { \partial q }, \tag{1}\\ Q &= \frac{ \partial F_2 } { \partial P }. \tag{2} \end{align}
Canonical transformation that preserve symplectic form
More recent literature, e.g., David Tong's lecture notes, tend to define a canonical transformation through the symplectic condition on the Jacobian from $x = (q, p)$ to $X = (Q, P)$: \begin{align} U = \frac { \partial{ X } }{ \partial x }. \tag{3} \end{align} As long as \begin{align} U \, J \, U^T = J, \tag{4} \end{align} we say the transformation is canonical, where \begin{align} J = \left( \begin{array}{cc} 0 & 1 \\ -1 & 0 \end{array} \right). \end{align} This is because \begin{align} \frac{dX}{dt} &= \frac{\partial X}{\partial x} \frac{d x}{dt} \\ &= \frac{\partial X}{\partial x} J \frac{\partial H}{\partial x} \\ &= \frac{\partial X}{\partial x} J \frac{\partial X}{\partial x} \frac{\partial H}{\partial X}\\ &= U \, J \, U^T \frac{\partial H}{\partial X}, \tag{5} \end{align} where we have assumed that the Hamiltonian of $X$ is the same of that of $x$, which is not necessarily the case, see e.g., this post.
Questions
Now the first question is
  1. Can all canonical transformations preserving the symplectic form, Eq. (4), be generated by one of the generating functions?
If so, it would be nice if we can explicitly construct such a generating function (that is, in a practical way).
The converse is
  1. Do all canonical transformations generated by one of the generating functions preserve the sympletic form?
If one of the statements is wrong, do we have some simple counterexamples?
Attempts
Now if we write \begin{align} U = \left( \begin{array}{ccc} A & B \\ C & D \end{array} \right), \end{align} Eq. (4) means \begin{align} BA^T &= AB^T, \tag{6.1} \\ CD^T &= DC^T, \tag{6.2}\\ AD^T - BC^T &= 1, \tag{6.3} \\ DA^T - CB^T &= 1. \tag{6.4} \end{align} Note that Eq. (6.4) is only the transverse of Eq. (6.3).
It is readily show that Eqs. (1) and (2) satisfies (6), at least in one dimension. Define $Y = (q, P)$, then \begin{align} U &= \left( \frac{ \partial X }{ \partial Y } \right) \left( \frac{ \partial Y }{ \partial x } \right) = \left( \frac{ \partial X }{ \partial Y } \right) \left( \frac{ \partial x }{ \partial Y } \right)^{-1} \\ &= \left( \frac{ \partial (Q, P) }{ \partial (q, P) } \right) \left( \frac{ \partial (q, p) }{ \partial (q, P) } \right)^{-1} \\ &= \left( \begin{array}{cc} \left(\frac{\partial Q}{\partial q}\right)_P & \left(\frac{\partial Q}{\partial P}\right)_q \\ 0 & 1 \end{array} \right) \left( \begin{array}{cc} 1 & 0 \\ \left(\frac{\partial p}{\partial q}\right)_P & \left(\frac{\partial p}{\partial P}\right)_q \end{array} \right)^{-1} \\ &= \left( \begin{array}{cc} \left(\frac{\partial Q}{\partial q}\right)_P & \left(\frac{\partial Q}{\partial P}\right)_q \\ 0 & 1 \end{array} \right) \left( \begin{array}{cc} 1 & 0 \\ - \left(\frac{\partial p}{\partial q}\right)_P \left(\frac{\partial p}{\partial P}\right)_q^{-1} & \left(\frac{\partial p}{\partial P}\right)_q^{-1} \end{array} \right) \\ &= \left( \begin{array}{cc} \left(\frac{\partial Q}{\partial q}\right)_P - \left(\frac{\partial Q}{\partial P}\right)_q \left(\frac{\partial p}{\partial q}\right)_P \left(\frac{\partial p}{\partial P}\right)_q^{-1} & \left(\frac{\partial Q}{\partial P}\right)_q \left(\frac{\partial p}{\partial P}\right)_q^{-1} \\ - \left(\frac{\partial p}{\partial q}\right)_P \left(\frac{\partial p}{\partial P}\right)_q^{-1} & \left(\frac{\partial p}{\partial P}\right)_q^{-1} \end{array} \right) \\ &= \left( \begin{array}{cc} \frac{\partial^2 F_2}{\partial q \partial P} - \frac{\partial^2 F_2}{\partial P^2} \frac{\partial^2 F_2}{\partial q^2} \left(\frac{\partial^2 F_2}{\partial q \partial P}\right)^{-1} & \frac{\partial^2 F_2}{\partial P^2} \left(\frac{\partial^2 F_2}{\partial q \partial P}\right)^{-1} \\ - \frac{\partial^2 F_2}{\partial q^2} \left(\frac{\partial^2 F_2}{\partial q \partial P}\right)^{-1} & \left(\frac{\partial^2 F_2}{\partial q \partial P}\right)^{-1} \end{array} \right). \tag{7} \end{align} It can be verified that Eq. (6.3), hence Eq. (4), is satisfied.
Edit: the second question is answered by Qmechanic in point 2 of this post. The answer appears to be true, in agreement with the observation of Eq. (7).
hbp
  • 174
These questions can be trivially answered if you know some basic symplectic geometry. I'll provide explanations here with a tl;dr if you don't cannot follow the details.
tl;dr: If the first cohomology group of the symplectic manifold is trivial, i.e. if ${\cal H}^1 ( M) = 0$, then every canonical transformation can be generated by a function.
Proof: Let $M$ be a symplectic manifold with form $\Omega$. A canonical transformation is a diffeomorphism $\xi$ on this manifold that preserves the symplectic form, i.e. $$ {\cal L}_\xi \Omega = 0 $$ But ${\cal L}_\xi = {\text d} i_\xi + i_\xi {\text d}$ and $\Omega$ is closed. Thus, the equation above can be re-written as $$ {\text d}( i_\xi \Omega ) = 0 $$ Now, if ${\cal H}^1 ( M) = 0$, then every closed one-form is exact. Thus, there exists a function $f$, such that $$ i_\xi \Omega = - {\text d} f $$ This $f$ above is precisely the generating function.
Finally, since $\Omega$ is invertible, this formula can be inverted to determine $\xi$ from $f$. Thus, there is a one-to-one correspondence between canonical transformations $\xi$ and generating functions $f$.
tl;dr: Yes. A canonical transformation is by definition a transformation that preserves the symplectic form.
This follows immediately from the discussion above. Any exact form is closed so any transformation obtained from a generating function as shown above is trivially canonical.
Prahar
  • 29,157
