Galileo stated that objects dropped from the same height will hit the ground at the same time, that the rate of gravity is constant for all objects no matter the mass. But I think there is a flaw in this statement.
All objects with mass have gravity. If a object has a greater amount of mass, it has a greater gravitational pull. Therefore, a hammer has more gravitational pull than a feather.
Given that the hammer and feather have gravitational pull, we can prove that the hammer falls faster than the feather, because it has more mass.
Because the hammer has a gravitational field, it is tugging the Earth toward itself a tiny bit, and the same with the feather. But since the hammer has more mass than the feather, it will tug the Earth toward it faster, meaning it would "fall" to the Earth faster if you dropped it.
Doesn't this mean that objects with greater mass fall faster, disproving Galileo?
