It is unknown whether the universe is discrete or continuous in its intricate quantum level structure.
See for example: Can universal continuity be experimentally falsified?
Is the universe finite and discrete?
How could spacetime become discretised at the Planck scale?
Is time continuous or discrete?
Even so, all branches of modern physics rely heavily on fully continuous structures.
From the Bekenstein bound applied to a black hole, we know that the Information entropy that can be contained inside a black hole is finite and proportional to the surface area of the event horizon.
From the No hair theorem/conjecture, it is believed that the black hole is uniquely described by mass/energy, linear and angular momentum, position, and electric charge, which amounts to a total of 11 real numbers. Possibly, if magnetic monopoles exist, we can add an additional number for magnetic charge.
Most physicists will argue that these 11 numbers are continuous (i.e. not bounded rational approximations).
With an assumption of real continuity, as the black hole undergoes change, for example taking on additional mass over a period of time, the 11 numbers will change as time flows over a continuous infinitude of real numbers, with no smallest increment of time. Each of the 11 numbers then, must assume values that are rational, irrational, transcendental, non-computable and non-definable, as they continuously sweep through the real number field.
In fact, if any number is sampled at random, i.e. at a random time, it will almost surely (i.e with probability one) be non-computable and non-definable. A non-computable and non-definable number has infinite Kolmogorov complexity and carries infinite entropy, as its shortest description is its own random and infinite digit sequence. How is that consistent with the starting assumption of bounded entropy?
Your argument completely fails to take quantum mechanics into account.
Consider an electron spin. If you measure the spin of an electron using a standard measurement corresponding to an observable, you can only get two answers, $|v\rangle$ and $|-v\rangle$, where $v$ is some direction in three-dimensional space. And yet, you can prepare the electron so its spin is in any of a continuum of directions (any direction in 3-dimensional space), and you can measure the spin of an electron along any axis in 3-dimensional space.
Further, the von Neumann entropy of the electron spin is one bit, despite the fact that it can be pointing any direction of space. And if you encode information in the spin of an electron, there is a theorem that you can only retrieve one bit.
Now, let's see how your arguments apply to the spin of an electron, which is a very well-understood phenomenon.
We know that the Information entropy that can be contained in the spin of an electron is finite and equal to one bit.
The spin of an electron is uniquely described by a 3-dimensional unit vector, which can be parameterized by 3 real numbers the sum of whose squares is one – so two real parameters.
How can two real numbers be characterized by one bit?
It's not clear whether quantum gravity lets you measure quantities with arbitrary accuracy. You certainly cannot measure the spin of an electron with arbitrary accuracy.
What your argument fails to take into account is that quantum information theory is different from classical information theory, and is extremely non-inutitive.
We don't know how to quantize space-time, but we can say that your argument that there must be a contradiction somewhere is not consistent with what we know about quantum mechanics.
Peter Shor
  • 11,536
And if you have astrophysical sources of collapse, then an external observer can always choose a coordinate system where the black hole has never formed and the where no event horizon has formed yet. And hence where there is no inside. So it is your choice to have them or not. And hence no physical conclusions can be drawn.
From the No hair theorem/conjecture it is believed that the black hole is uniquely described by mass/energy, linear and angular momentum, position, and electric charge, which amounts to a total of 11 real numbers.
The no hair theorem is about solutions that real solutions come closer and closer to approximating as time progresses.
Which is a coordinate v system artefact. You can choose one where it never forms. And as long as one person can do that, no physical conclusion can be drawn from assuming it does form.
And that is non physical as well. All you can do is interact with something based on a the material available, you don't have the ability to invoke random times. Sure if something isn't generic you shouldn't expect to be able to see it in a controlled setting. But you can't just a sum E you can do things if you can't actually do them.
Entropy is about knowledge, and groupings of possible states consistent with coarse graining knowledge. How is that related in the slightest?
Timaeus
  • 26,055
  • 36
  • 71
-3
Is Bekenstein entropy limit inconsistent with universal continuity?
Yes, but that doesn't mean the Bekenstein bound is correct and everything is fine. Entropy can be considered as "sameness", related to available energy. And the expression $S \leq \frac{2 \pi k R E}{\hbar c}$ has a c in it, but the coordinate speed of light at the event horizon is zero.
A photon has its E=hf quantum nature, but that doesn't mean it approaches you in steps. It's quantum field theory, and the wave nature of matter. IMHO there's no evidence at all for a universe that has some "discrete intricate quantum level structure".
I'd say the universe appears to be continuous.
From the Bekenstein bound applied to a black hole, we know that the information entropy that can be contained inside a black hole is finite and proportional to the surface area of the event horizon.
We don't actually know that, it's hypothetical.
Which is also hypothetical.
There's potential issues with the angular momentum and charge and magnetic monopoles. But I'll go with the flow.
Note that a particle such as an electron has unit charge. But again, I'll go with the flow.
Fair enough.
The 11 numbers must then each assume values that are rational, irrational, transcendental, non-computable and non-definable, as they continuously sweep through the real number field.
OK.
The number does not actually exist. A bl;ack hole exists, and a photon exists. This photon can fall into the black hole increasing its mass/energy by E=hf, and E can take any value. But we can't say that a black hole consists of n photons or is anything to do with statistical mechanics or information theory. Note the black hole information paradox: "The black hole information paradox[1] is an observational phenomenon that results from the combination of quantum mechanics and general relativity which suggests that physical information could permanently disappear in a black hole, allowing many physical states to devolve into the same state". For all you know the photon totally loses its identity, and the black hole is like one big boson, where everything is the same. For all you know the black hole could be something like a BEC, and subject to a Bosenova.
Sorry this doesn't give you anything definite, but so much of this stuff is hypothetical.
John Duffield
  • 11,381
