Suppose there is a snooker ball rolling on a table. The velocity of the center of the ball is Rω and its direction is horizontally right. I don't understand why the point right below the center on the ball has zero instantaneous velocity. Much obliged if anyone can help me.
Asked
Active
Viewed 315 times
The ball is rolling along positive x direction with velocity v. The points of the ball directly below the center are rotating around the center of the ball in the -x direction with instantaneous velocity u equal to the distance from the center of the ball times the angular velocity of the ball. Where v = u you have the condition you are looking for.
Truly there is a line below the center of the ball perpendicular to the direction of v where all points on the line have the same zero instantaneous velocity.
user93982
- 121
