I was inspired by this interesting question on this forum:
How do I measure an earth year without a clock?
Say you're stranded on an alien planet without any significant tools. How would you recreate the SI system of units with some accuracy?
The meter is fairly easy within less than 1% since most people know their height to within a cm or less than an inch.
How about the second? Given the unreliability of biological clocks, I'd have to measure it. But I can't use a pendulum because I don't know $g$. I can't build a mechanical mass-spring system because I don't know the stiffness of materials (in general). To measure stiffness I'd have to re-create the SI Newton, which is a derived unit from seconds.
- How could you re-create the SI second? The least technically complicated answer the better (pendulums beat RC circuits which beat atomic clocks and radioactivity measurements).
- Is the only way to re-create the second is to measure $c$ or build an RC circuit (basically the same things since I can use $\varepsilon_0 =\frac {1}{\mu_0 c^2}$)?
- If point 2 is correct, how would you measure $c$ or build an RC circuit in the most simple manner?
Myself, I believe that (1) is not possible with mechanical systems, because (2) is true for classical mechanics so I'll have to build an optical interferometer, a radio/receiver to measure c, or an RC circuit. For point (3) given copper wire and iron (which are thousand year old technology) it's possible to build a magnetic amplifier radio and try to measure the time to bounce off an obstacle.
Thoughts?
EDIT: This is different from If time standard clocks and any memories about the time standard are destroyed, can we recover the time standard again?. That question assumes I'm still on Earth, and I'm possibly a member of civilization. Then I can re-create the meter fairly accurately from it's original definition as a fraction of the circumference of the Earth, and for the second I can build a pendulum of period 1s, since g has not changed.
The challenge here is, given a facts that a reasonably educated person would know (their height, the value of c and how it relates to other values. I know some basic astronomical facts but don't know the names and position of all the uncatalogued stars), excellent physics knowledge (i.e. I understand special relativity, lie grouops, ect) and perfect mathematical ability (I can derive any known mathematical result I need) can I recreate the SI system within a reasonable margin of error?
Also, people have asked if they can assume certain things (i.e. can I see Jupiter, does the planet have an earth). Assume away, you'd be answering interesting specific cases and exploring other techniques. However, the more general the answer, the better.
Finally, if there are any doubts read the original question at the very top. I'm ultimately trying to get a satisfying answer for that scenario.
