I'm currently reading about Maxwell's law of distribution of velocities, and the thought occurred to me that I could use this to calculate the maximum temperature that an atom could reach.
My theory is that there is a temperature at which atoms would exhibit movement equal to $c$, and hence could not move any faster.
Using the average velocity formula to calculate $T$ where $\bar{u} = c$ for a hydrogen atom (Wolfram Alpha):
$\bar{u} = \sqrt{8RT\over\pi M} \\\bar{u} = c \\ M = 2 \\ c = \sqrt{8RT\over2\pi} \\ T = 8.494352186809165 \times 10^{12} K$
Given that I haven't found any evidence of this theory online, I assume that I've made a mistake.
Is this correct or not, and why?
An interesting side note to think about is that under this theory, an atom heated to this temperature would have infinite mass.
Comments already hinted at this, but the simple answer is that when you wrote the average velocity as a function of temperature, you were using a non-relativistic approximation (which is valid for most "everyday" situations, but not at extreme temperatures). Furthermore, since the particles have a mean velocity $\bar u$, you can't simply set that equal to $c$ as many particles would have then to go faster than the mean... whichever way you look at it, your analysis doesn't work.
Instead, you can use the more general equipartition theorem that states that every degree of freedom of a particle in a gas has an energy of $\frac12 kT$
You could write an expression for the kinetic energy in one dimension:
$$E = \frac{p^2}{2m} = \frac12 kT$$
Note that I got rid of "velocity" and instead expressed the result in terms of momentum. As you know, momentum will continue to increase as a particle gets closer to the speed of light, because it will become more massive.
How best to calculate the "mean" velocity becomes tricky - the velocity distribution is no longer following the classical distribution. The actual velocity distribution at relativistic velocities is the Maxwell-Jüttner distribution which converges to the Maxwell-Boltzmann distribution at non-relativistic velocities (tip of the hat to Kyle Kanos for pointing this out).
All of which is a long winded way to say "There is no upper limit on temperature".
Floris
  • 119,981
Maxwell's distribution of velocities has been derived through classical arguments. It does not take into account relativistic effects. You don't need to evaluate anything to see that; just observe that it accepts arguments (velocities components) over the whole real line and does not have a cut-off at the speed of light. So it gives a non-zero probability even for superluminal velocities
