Mass appears to attract other mass, irrespective of position or orientation. That is, gravity is attractive no matter what. Contrast that with electrostatic forces which could attract or repel depending on the charges involved, or a voltage between two metal plates which has a specifically directional force on electrons travelling through it.
How do we know gravity attracts in all directions at once? What experiments have been done to confirm this?
Researchers1 placed thousands2 of fast-moving objects3 in a wide variety of orbits around a convenient planet4 and then carefully monitored5 the motions of the biggest 22000 of them.
So far no one has noticed any object whose path deviates significantly from that predicted by the omnidirectional models.
1 Well, a variety of organisations put them there. The researchers are a subset.
2 About 370,000.
3 Up to 22,000 MPH.
4 Sol-3, Earth.
5 E.g. http://orbitaldebris.jsc.nasa.gov/measure/measurement.html
You're looking to prove a negative; science doesn't work like that. Every experiment that has ever been carried out has shown that gravitational forces are attractive; no experiments have ever shown repulsive gravitational forces between masses.
Alby
  • 132
-7
Because my daughter in Australia tells me her pencil falls down, not up.
Yes it is. Note that a concentration of energy causes gravity, not just mass. It's usually in the guise of a massive star, but it's the E=mc² energy content that causes the gravity. And then a passing light beam curves towards the star, not away from it. See Ned Wright's deflection and delay article:
In similar vein matter falls down towards the star. IMHO to understand this all you need to do is think of pair production and the wave nature of matter.
Electromagnetism doesn't work the same. The electron has a "spinor" nature, and the positron has the opposite chirality.
When you go to Australia, you don't fall off the bottom of the world!
John Duffield
  • 11,381
