I know that the velocity of light with respect to anything is constant ($c$) . What, then, is velocity of light with respect to light?
When you say that an object $A$ has some velocity with respect to another object $B$, you are implying that there is a reference frame where $B$ is at rest, and $A$ moves with the aforementioned velocity in that reference frame. It makes no sense to talk about the movement of a photon with respect to another, because photons have no rest frame.
See: Why can't we make measurements in a photon's rest frame when loop diagrams make measurements possible? and Does a photon in vacuum have a rest frame?
- 7,538
When you say that an object $A$ has some velocity with respect to another object $B$, you are implying that there is a reference frame where $B$ is at rest. This means that additional participants ($J$, $K$, ... $P$, $Q$ ...) can be thought of (or can even be actually identified) who were and remained at rest with repect to $B$, and with respect to each other. Then
either $A$ had passed some other members of the rest frame to which $B$ belongs, and eventually reached $B$ (and possibly even passed $B$). Let's say that $A$ had passed $K$, $J$, etc., but not $P$, $Q$, or others. For each passage we can evaluate the average speed of $A$'s motion wrt. $B$ and $K$, wrt. $B$ and $J$, and so on. Evaluating the limit of these speed values (if there is one) we obtain the instantaneous speed of $A$ at $B$'s indication of the passage of $A$, and we attribute a direction to $A$'s motion wrt. $B$'s rest frame (say "from $J$ to $B$").
Or: $A$ is a member of this rest frame, too; accordingly $A$ and $B$ were at rest to each other, and the value $\vec 0$ is evaluated for $A$'s velocity with respect to $B$.
But it makes no sense to attribute a value of velocity to one photon with respect to another, because photons have no rest frame; photons cannot be said to have been at rest with respect to each other. Arguably it doesn't even make sense to talk about the movement of a photon with respect to another, at all.
See for instance: "Are signal fronts in a beam not at rest to each other?" (PSE/q/104333).
