52
Why are golden mirrors yellow?
Do they add a yellow component to the spectrum or absorb non-yellow components?
If they absorb, then why are they used in telescopes being imperfect?
If they add a yellow component, then where do they take energy for it from?
JWST mirrors are coated with gold
Gold-coated mirror
Do they add some corrections in the on-board computer to compensate for the color of gold?
psmears
  • 334
Dims
  • 1,752
  • 14
  • 27
I've made this into an answer because it's too long for a comment, and I really want to show the pictures.
It is tempting to think of visible light as "close enough" to (near by wavelengths) and to conclude that "yes, actually, the yellow does affect it. I want a mirror without an obvious tint"
However you are wrong, Physics will slap you down.
Exhibit A
Infrared lens
(There's a book called Optics by Eugine Hecht that has a picture of some such lenses, but I couldn't find that picture. This is the best I found with quite a bit of googling)
This lens is made from "silicon or germanium" according to this link (where I found the picture) - I could have swore it was steel, anyway!
This lens is completely opaque to us, but to actual infrared cameras (the 1-$\mu$ sort of wavelengths) this is probably a good lens!
Let us go further.
Exhibit B
For reference this is 22.5cm tall
Radiowave lens
This is a lens for radiowaves. As you can just about see, it doesn't even "refract" our visible light, that light just goes right through the MASSIVE GAPS in the mesh. However to radiowaves, this is a lens!
Exhibit C
Finally, we come to visible light, I took this picture (bit of shameless "I'm proud of this", I know):
Dog being a little shit
As you can probably tell from the soft background and such it was taken with a lens with a very large aperture (50mm f/1.4), and as you can (hopefully not) see the different wavelengths of light have actually gone different paths through the lens. Notice:
Wavelengths distorting through a lens(?)
As you can see, "glass" isn't even very good at treating the visible wavelengths the same way. A picture is worth a thousand words.
Wavelengths of light through a lens
I used a good lens, which is why the effect is so small, but this shows the principle behind it.
Exhibit D
Microwave door
This is a microwave door - it is opaque to microwaves, but as you can see, lets visible light through. (See Faraday Cage)
Exhibit E
WiFi. It can pass through walls and doors.
It should be clear now that light doesn't exactly behave like what our brain calls "light"
Finally
I hope this helps. As you can see - WAAAY to long for a comment.
nhahtdh
  • 105
Alec Teal
  • 832
56
If you look at the reflectivity of gold (vs silver or aluminum) you can see a plateau at wavelengths below 500 nm source:
If blue wavelengths are not reflected as well as other colors, the resulting image will look "more yellow" - which is what you see.
At longer wavelengths, gold is a very good reflector (better than the other two above 600 nm). It also doesn't tarnish, so its reflectivity is less affected by atmospheric contamination.
If you need anything approaching accurate measurement, you have to calibrate your system at any rate - beside the mirrors and lenses, you need to consider the response of the detector, effects of the atmosphere, and pretty much everything in (or near) your optical path. Serious photometry needs serious calibration, as Chris White pointed out in the comment.
Floris
  • 119,981
