When the initial velocity is perpendicular to the magnetic field, the force acting on the charged particle
F = qvBsin(theta)
F = qvBsin(90)
F = qvB
In my textbook, it is given that the force will continually deflect the particle making it move in a circle. It also says that as the magnetic field acts on a particle perpendicular to its velocity, it does not do any work on the particle, it doesn't change the kinetic energy of the speed or the particle.
However, how come that it doesn't change the speed or the kinetic energy? We do have force acting on the particle which means that there will certainly be some accerleration.
tok3rat0r
  • 799
The power (work per unit time) of a force $\vec F$ on a particle with velocity $v$ is given by: $$ P = \vec F \cdot \vec v.$$ If this number is positive, then the force tends to speed the particle up. If it is negative, it tends to slow the particle down. You can see this in the Work-Energy theorem, the differential form of which consists of applying Newton's law to this as if it's the only force acting on the particle: $$ P = m {d\vec v \over dt} \cdot \vec v = m~~\frac{1}{2}~{d \over dt}\left(\vec v \cdot \vec v\right)$$We see that $\vec v\cdot\vec v$ is the speed squared and has no dependencies on anything other than the speed, moreover this is increasing with time when the power is positive, or decreasing when it is negative, or zero when it is zero.
Now, the thing about that dot product, $\vec F \cdot \vec v$, is that it is zero whenever those two vectors are perpendicular. So a force has to have some component in the direction of your velocity.
Magnetic forces do not have this: their Lorentz force is $\vec F = q \vec v\times\vec B$, always perpendicular to velocity. Magnetic forces cannot do work directly. To calculate, say, two magnets attracting each other, you always need to see what sorts of electric fields are getting induced, or at least calculate the energy density in the fields before and after.
CR Drost
  • 39,588
Then an electron moves non-parallel to a magnetic field it get deflected. But the curve the electron describes is not a circle. The electron moves on a spiral path and this time it slows down to zero velocity. To be precise the spirale path is a path made from "tangerine slices". How does this happens? The reason for the so called Lorentz force is based on the electron's magnetic dipole moment and in connection with it the electron's intrinsic spin.
When a moving electron get influenced by a non-parallel to the movement magnetic field the his magnetic dipole moment gets aligned and the electron's intrinsic spin gets by this aligned too. Due to the gyroscopic effect the alignment of a rotating object led to the deflection of this object. The alignment of the intrinsic spin and the deflection are accelerations and that is why the the electron emit photons. The photons take some moment from the electron and the electron brakes. This is a periodical (iterativ) process and the reason for the tangerine slices.
HolgerFiedler
  • 10,980
The velocity vector is changing all the time. The magnitude is constant, but the direction is changing all the time (circular motion). So, the Lorentz force, which is perpendicular changes $\vec v$ without changing its magnitude $v$, which is prohibited as the energy increase is $\vec F . \vec v =0$.
jac
  • 770
