I was discussing with my colleagues why it feels easier to walk up an escalator when it is moving. My natural assumption was that the movement of the escalator imparts some extra acceleration on the rider that helps to move up the stairs. But my colleagues insisted that this was nonsense, and that the affect is purely psychological (i.e. it just seems easier).
We actually came up with three contradictory hypotheses, and I'm not sure which is right: 1. The escalator is constantly accelerating the rider since without constant acceleration the body wouldn't be able to counteract the force of gravity (i.e. my theory). 2. The rider is not accelerating since no acceleration is needed to maintain a constant velocity. 3. The acceleration of the escalator actually makes it harder to get to the next step since it pushes the rider against the current step.
Which of these is correct?
Once you get yourself moving, the escalator does not accelerate you and does not assist your running up hill. The only advantage an escalator gives you is that you keep moving up even if you don't put any effort into it.
Next time you feel like running up an escalator (which is not entirely safe), you might consider repeating the experiment with your eyes closed. That will eliminate the visual effect but you will still feel the air flow on your face.
This is basic Newton's law on inertial frames. You cannot detect steady motion. This is why you can throw dice in the gambling compartment of a luxury airliner that is moving at 400 miles per hour. Or why you can exist on the earth's surface without realizing that it is moving (due to the earth's turning) at an even faster rate (depending on latitude).
Carl Brannen
  • 13,059
Number two is correct:
2.The rider is not accelerating since no acceleration is needed to maintain a constant velocity.
The first option offered:
1.The escalator is constantly accelerating the rider since without constant acceleration the body wouldn't be able to counteract the force of gravity (i.e. my theory).
Here's why that's wrong.
To apply Newton's second law, $F = ma$, all system forces and their interaction must be taken into account. If you hold an object in the palm of your hand, you are applying some force on that object, but that object is not accelerating and it's not even moving. This is because the force you apply on that object is equal and opposite to the force of gravity.
In the case of an escalator, a motor provides some torque (rotational force) which is acting agianst forces of friction in the system and gravity which weighs down the passengers. After all forces are taken into account, the velocity of the escalator is (approximately) constant therefore the acceleration is zero and walking up those stairs is no easier than walking up a regular set of stairs.
Walking up the stairs of an escalator may even be more difficult than walking up a regular set of stairs because increased velocity relative to the surrounding atmosphere causes an increase in fluid friction acting on the walker.
Ami
  • 333
A certain version of the 3rd option is correct.
Let's analyze the case for a person that just stands on a step of the escalator.
The person comes walking at a certain speed, presummably the same as the horizontal speed of the escalator's speed, so when the step into the platform is taken no acceleration occurs. But shortly after, the platform changes direction and starts going upwards. In this moment vercical acceleration is imparted to the person's body. Once the platform is moving at full escalator angle, both horizontal and vertical speed are constant, thus there is no acceleration in any axis.
The short period of vertical acceleration is usually not felt by the person because knees are amost locked straight so the force is excerted mostly trhough the bones, however, if you step on the escalator with knees slightly bent, you'd experiment (feel, perceive) the force needed to remain (half) standed.
Now, since after the initial direction change there is no more acceleration from the escalator, if the person takes their own steps forward/upward then with each step they would be accelerating the body up and forward. This acceleration results obviously in higher speed.
So, the escalator makes it easier to get up to the next deck, but each individual step would take the same energy from the body of the person performing the experiment than it would take if the escalator was stopped.
There are a few things to consider:
The phicological effect of perceiving a higher speed, not correlating to the perceived effort.
The fact that you walk less steps to get to the upper deck if the escalator is functioning (upwards).
Finally, consider what happens if besides the escalator there are regular stairs. If you try to walk up the stairs at the same speed (relative to the building) than a person walking up the working escalator, you'd find how you need more effort to accomplish the task in the same time.
Jahaziel
  • 101
